Old 03-07-2020, 11:13 PM   #1
brandonleetran
brandonleetran's Avatar
Drives: SWP Subaru BRZ
**HELP** Heated Seats Stopped Working
I removed the connectors so I can take out the heated seat switches to clean them. After wiping them down, I connected everything back (even the cig connector), however my heated seats stopped working. The lights won't turn on, and I tried to see if the seats would work even if the lights wouldn't turn on.
Am I missing anything here guys? Thanks in advance. Im new to this.
brandonleetran is offline   Reply With Quote
Old 03-07-2020, 11:17 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
first things first, check the fuses in the drivers side footwell.
Old 03-07-2020, 11:22 PM   #3
brandonleetran
Checked the fuses, they work fine.
Old 03-07-2020, 11:34 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Do you own/know how to use a multimeter?
Old 03-08-2020, 01:09 AM   #5
I'll guess you put the connectors back together wrong.
Yep, a multi-meter is a useful tool.
Back in the day we had these little store bought test lights.
Further back in the day we would make a test light with a 6-V light bulb and two pieces of wire.
Before that, we would wear a "car coat" in the wintertime.
Racoon coats worked good back in the buggy days.
Got to go, it's time fer ma meds -
Old 03-08-2020, 05:49 AM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
How did you "clean" the switches?
And exactly what lights won't go on? The lights on the switch?
If so, I would say you don't have the switches re-connected correctly, or you ruined them.
Old 03-09-2020, 03:15 AM   #7
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
I ran into a similar scenario when removing the centre console panel. I didn't disconnect the battery before disconnecting the seat heater and power outlet connections.
as it turns out, I actually blew each lightbulb in the seat heater switches. the switches themselves still worked and still provided heat.
I would use a multimeter/voltmeter to check and see if you have heat.
Start with the actual fuses though.
jbsali is offline   Reply With Quote
heated
Heated Seats not working after Headunit install/ Console Removed jbsali Issues | Warranty | Recalls / TSB 10 10-10-2019 11:22 PM
Heated seats stopped working macaulay7 Electronics | Audio | NAV | Infotainment 9 08-28-2018 05:41 PM
BRZ Heated seats stopped working? Bd792010 Electronics | Audio | NAV | Infotainment 0 08-28-2018 05:16 PM
Key Fob stopped working SmartedPanda Electronics | Audio | NAV | Infotainment 2 05-06-2017 02:40 PM
drl stopped working! help. blkmamba Issues | Warranty | Recalls / TSB 10 09-29-2016 07:52 PM
