Old 03-07-2020, 10:48 PM   #1
BleachBlanket
Drives: Subaru BRZ 2014
Catted vs. catless?
Hello peeps,
I’m running a catless uel header. Unfortunately, to pass emissions (every 2 years) I have to swap back to stock catted header. Not a difficult task when I have the time and the weather’s ok- no garage.
Anyways, if I got a catted uel header, what kind of gains will I loose?
BleachBlanket is offline   Reply With Quote
Old 03-07-2020, 10:52 PM   #2
p1l0t
p1l0t's Avatar
Originally Posted by BleachBlanket View Post
Hello peeps,
If it's just a visual inspection you just need a pipe with a bump in it...
Old 03-07-2020, 11:56 PM   #3
Hello peeps,
Welcome to our happy group, there, BleachBlanket -
You wouldn't notice the difference, as long as you stay out of the timing traps at the drag strips and stay off the dynos -
mrg666 (03-08-2020)
Old 03-08-2020, 01:04 AM   #4
Dake
Dake's Avatar
Cats have come a long way since the 70's and unless you're also running boost of some sort, you probably aren't seeing any significant HP gains by removing yours.
If you weed out the usual internet hearsay, people that have dynoed before and after show very little loss, to even a slight gain [ame="https://www.youtube.com/watch?v=OSMcHg_7eo4"]slight gain[/ame] with cats installed.
To put it in even better perspective, here's a post someone did where they dynoed 15 86's the same day, with a mix of OEM, tuned, catted, non-catted and so on. The numbers support the cats don't make a huge difference. In fact, there's a tuned 86 with no-cat, UEL headers on 93 gas and it only makes 3 more HP than a plain-jane factory 86. Heck, an otherwise stock 86 with the OFT E85 tune makes 9 more HP than the non-catted car.
So, while it's only two every two years, you're making more work for yourself, and spitting more crud into the air for a potential gain that you could also see if you just took a good dump before hitting the track day.
Dake is offline   Reply With Quote
The Following 7 Users Say Thank You to Dake For This Useful Post:
BigHugeFatGuy (03-10-2020), ElijahF (03-11-2020), humfrz (03-08-2020), Irace86.2.0 (03-10-2020), p1l0t (03-08-2020), ROFL it's Waffle (03-07-2023), Tcoat (03-09-2020)
Old 03-09-2020, 12:19 PM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Or they can see his front pipe if it's stock
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 03-09-2020, 01:35 PM   #6
p1l0t
p1l0t's Avatar
Oh we don't have rules like that in CT just need to have a cat (bump in pipe) and no CEL with sensors readied.
Old 03-09-2020, 01:46 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
In MD, you have a bored state-employed "technician" (probably making minimum wage) plug the computer in to take a reading and print a piece of paper.
Old 03-09-2020, 02:09 PM   #8
Like so many "power increasing" mods they can work wonders on some cars and mean almost nothing on another but everybody just looks at the gains from the first group and thinks they apply to all cars.
Take a 1993 Civic DX replace the 1 1/4" exhaust with a 2" non catted system, swap a header for the exhaust manifold, change out the hot engine bay sucking intake for a real cold air snorkel and even without a tune it will make a huge difference. Swapping out those same parts with very similar aftermarket ones on a Twin is not going to gain you much if anything.
It is the simple difference of turning a "normal" car into a performance one vs trying to improve a car that was designed for performance from the start. They can of course be improved but it isn't near as easy as turning your mom's old Civic sedan into a sleeper.
Dake (03-09-2020), p1l0t (03-09-2020), ROFL it's Waffle (03-07-2023)
Old 03-09-2020, 05:22 PM   #9
Jordanwolf
Rice King
Jordanwolf's Avatar
Just shed some weight bro, those are the best gains. You or the car.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
SuperTom (03-09-2020)
Old 03-09-2020, 07:00 PM   #10
ElijahF (03-11-2020), Jordanwolf (03-10-2020)
Old 03-09-2020, 08:48 PM   #11
gravitylover
This whole catless things is so annoying. I guess if you don't remember what it was like to be in the big cities and not be able to see across the river or sometimes even 10 blocks back in the late 60's and early 70's.
The Following 4 Users Say Thank You to gravitylover For This Useful Post:
Dake (03-10-2020), ElijahF (03-11-2020), Irace86.2.0 (03-10-2020), Tcoat (03-10-2020)
Old 03-09-2020, 09:37 PM   #12
86MLR
86MLR's Avatar
From my experience
You do see a nice power gain from removing OEM cats, after tuning of course.
Alot of high flow aftermarket cats (100-200 cell) though will not pass your cars emmisions sniffer test requirements, even some 400 cell cats won't pass.
And sometimes, even when your highflow cat doesn't trigger a CEL code, you will fail a sniffer test.
In the end, if your not chasing that tenth of a second you are better off having a decent OEM cat/s and the car tuned to comply.
Or, risk it for the biscuit
Old 03-10-2020, 12:32 PM   #13
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I'd be surprised if they were inspecting the header cat. I think they are looking for the one on the FP.
But thats just based on what they do here in Australia.
Blighty is offline   Reply With Quote
Old 03-10-2020, 12:40 PM   #14
It is very nostalgic in a horrible sort of way when I am behind or beside an uncatted car. The annual car show I attend with 300 or so classic cars stinks the main street up when the parade passes by. God I do not miss that smell!
ElijahF (03-11-2020), gravitylover (03-10-2020), Irace86.2.0 (03-10-2020)
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? l3ooml3al2al3a Engine, Exhaust, Transmission 12 03-22-2019 11:22 AM
Trade JDL UEL Catted for my JDL UEL Catless brzgabriel47 Southern California 1 08-12-2018 02:56 AM
Question about catless to catted fp with OFT ANTLAY Software Tuning 5 12-14-2015 05:32 PM
Catted or catless trsiidno Engine, Exhaust, Transmission 1 01-12-2015 04:36 PM
WTT: catless downpipe for catted mr. slim Want-To-Buy Requests 1 09-30-2014 07:18 AM
