Old 02-18-2020, 02:56 PM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Genuine SARD vs Sard "style" Wing
I know there is a huge price difference between the 2. Curious about the construction and weight differences
Genuine - is it full Carbon Fiber construction for the price, Also total weight?
Knockoff- same question full CF, or CF over a fiberglass base?
Weight according to FT86speedfactory is ~5.5lbs which isn't too bad.
Thanks in advance.
SuperTom is offline   Reply With Quote
Old 02-18-2020, 04:47 PM   #2
HaXx
Drives: jrsc_brz
I had the sard style carbon wing on for about a year and it was great. Only thing that happened was the bases faded brownish because they are anodized black, and anodizing fades in the sunlight. Car was parked outside at work all day. But I would absolutely get it again, I'm just going carbon trunk.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Joveen (02-18-2020)
Old 02-18-2020, 05:48 PM   #3
SuperTom
SuperTom's Avatar
Something like the legs/base is no big deal, can always be repainted. More concerned with the wing construction itself.
Mine will be outside all the time as well how is the CF holding up as far as clearcoat peeling/yellowing?
Thanks for the input!
The Following User Says Thank You to SuperTom For This Useful Post:
HaXx (02-18-2020)
Old 02-18-2020, 09:13 PM   #4
HaXx
Drives: jrsc_brz
the clear coat was flawless, no sun fading. and truth be told i was its second owner, and even by the end of my ownership the carbon deck and its clear was flawless. i mean photo ready. so u should def kep feelers out for a sard style, they do come up, and when they do they go fast.
Old 02-18-2020, 10:35 PM   #5
StraightOuttaCanadaEh
Wes
The carbon is FRP wrapped in carbon. I used to have the FRP sard style one and the bracket rubber shims that hold on to the edges of the trunk eventually disintegrated and left 2 bumps on each side of the trunk where the bolts have to be tightened. Not sure if that’s because it’s a rep. Also at highway speeds it wobbled very noticeably, don’t know if the “carbon” version would remedy that.
Instagram: @gt86ws
Old 02-18-2020, 11:06 PM   #6
SuperTom
SuperTom's Avatar
Thank you for your honesty. Im currently a CF trunk wingless.
Do you think the wobble had to do with the disintegrated rubber shims? or was it always like that?
Old 02-19-2020, 01:15 AM   #7
HaXx
Drives: jrsc_brz
i never had wobble, what cf trunk are you on? u gonna mount the sard to that?
Old 02-19-2020, 08:52 AM   #8
SuperTom
SuperTom's Avatar
Seibon Dry Carbon trunk. Main reason looking at the SARD is the ability to unmount it , preferably with no damage to the trunk
Old 02-19-2020, 01:45 PM   #9
Wes
To elaborate a bit, the wobble was the wing itself going up and down in the airstream, not side to side. The supports are solid, it seemed as if the wing blade itself lacked sufficient rigidity.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
BRZ Guy (11-27-2024)
Old 02-19-2020, 02:03 PM   #10
SuperTom
SuperTom's Avatar
Did you buy yours new or used from someone.
That would be a problem as Im guessing the bolts to screw into are molded into the fiberglass. The only could think to secure it would be drill a hole on top of the wing down. A countersunk bolt might not be as much as an eyesore
Old 02-19-2020, 03:08 PM   #11
Wes
New. So I’m wondering if the CFRP version would be a tad more rigid on the account of the carbon on the surface taking some of the flexibility away. You could for sure do supports just like the Perrin ones for the STI wing. But as far as I can tell, that would have to be custom made and probably cause additional holes in the trunk.
Instagram: @gt86ws
[WTB] Sard LSR Style Wing Tloi Want-To-Buy Requests 1 11-03-2018 07:04 AM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 08:52 PM
WTB:-SARD style wing dattran86 Canada Classifieds 7 03-11-2017 09:26 AM
LF: Used SARD Style Wing. FujiwaraTofu86 Canada Classifieds 16 12-15-2016 12:18 PM
SARD 86 GT1 Body Kit + SARD LSR Wing nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 1 04-27-2015 01:41 PM
