Old 02-10-2020, 05:01 PM   #1
jstn
Drives: '15 Vortech Supercharged
Catch can recommendations for Vortech supercharged?
I was looking at the Radium dual kit but $400 seems like a ton of money for this sort of thing and I could buy a pair of basic universal Mishimoto cans for like $200 and just figure out the plumbing and mounting myself.
I bought the car with the SC kit and a full exhaust installed by the previous owner, but no other supporting mods done. This is not a track car though and will never see much more than highway pulls and some light touge type driving. I'm spending this winter bulletproofing it (catch cans, radiator, cam plate) in preparation for a small pulley and professional tune.
jstn is offline   Reply With Quote
Old 02-10-2020, 05:54 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
The mishimoto or ebay replicas will do the job for a supercharger. If money is an issue look at the racerx ones.
https://racerxfabrication.com/frs-br...stem/catch-can
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 02-12-2020, 06:17 PM   #3
Grady
Grady's Avatar
No catch can.
Old 02-12-2020, 09:38 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Grady View Post
No catch can.
^Not this.
At minimum do one off the PCV. You might piece one together for less but there might be less quality too. I went cheaper with something on Amazon, and I question the quality. It catches stuff, but it isn’t perfect because the seals and connections aren’t perfect. I added baffling by putting steel wool in mine for increased surface area. It is probably an area where I will upgrade in the future, but at least it is working for now.
Old 02-13-2020, 12:45 PM   #5
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I'm a fan of the radium setup, one catches a good bit, never had to empty the second one.
B T is offline   Reply With Quote
Old 02-13-2020, 03:04 PM   #6
Try Again
Drives: 13' Brz
I run radium single catch can with sti pcv valve. The other side i just VTA with a hose and small filter on it.
Try Again is offline   Reply With Quote
The Following User Says Thank You to Try Again For This Useful Post:
tomm.brz (02-13-2020)
Old 02-14-2020, 08:47 PM   #7
jstn
Which one is the one that is actually catching a lot? I have a pair of basic cans on the way to try out and the PCV side seems easy enough but I couldn't find any information on doing the other side in terms of what hoses go where. If that one isn't really useful I'll probably just leave it alone and save the extra can for another car.
I'm also a fan of the Radium set up but it's a lot of money and pretty overkill for my car.
Compression Ratio for Supercharged w/ Vortech Gopherboy6956 Engine, Exhaust, Transmission 15 12-13-2017 06:14 PM
Catch Can recommendations for FI FullTuneZN6 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 06-19-2016 02:50 PM
NY Brz Vortech Supercharged Ny Brz Member's Car Journals 47 06-22-2015 04:30 PM
My Vortech Supercharged 86 now at 300whp! Bl1tzkr1eg Forced Induction 39 04-06-2014 02:10 PM
Vortech supercharged....sold Subby_brz Engine, Exhaust, Bolt-Ons 3 12-03-2013 10:56 PM
