Old 02-02-2020, 05:48 PM   #29
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Assuming everything works properly on startup, vvt should enable within 5 seconds. Typically right away.
Id start with techstream to narrow the possibilities.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following 2 Users Say Thank You to Tonrogs For This Useful Post:
DarkPira7e (02-02-2020), Ultramaroon (02-02-2020)
Old 02-02-2020, 06:10 PM   #30
tomm.brz
Drives: brz 2017 hksv2
@Ultramaroon
i ll show you a log of my car just after the rebuild
I threw a rod and bent intake cam #1 together with 2 intake valves
Subie mechanic didnt want to change the variator of that cam but in the log you can see how much it oscillated
https://datazap.me/u/tommbrz/prova-b...&data=12-30-31
Anyway, vvt activated always and after 30km it fixed itself and engine worked perfectly, as per log of today afternoon I posted before of a cold start
Then i started again the car and now vvt doesn t enable and cam intake #1 oscillates super quickly from - 0.6 to 1.1
Could be the variator that needs to be changed? is that spool valve part of it?
Old 02-02-2020, 08:31 PM   #31
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm going to try just changing out the oil. I shouldn't have to but it's worth a shot. Thanks for your participation everyone; maybe we can unravel more about the VVT system
Old 02-02-2020, 08:35 PM   #32
Tonrogs
I assume you do not have an oil pressure gauge?
Also, if you use techstream, you could rule out the oil as being a potential cause to this issue.
Old 02-02-2020, 08:42 PM   #33
DarkPira7e
DarkPira7e's Avatar
I don't have one, you're correct. I don't have techstream either. Might be worth getting
Old 02-02-2020, 09:44 PM   #34
Tonrogs
it definitely is worth getting. Just need a $15 adapter from ebay.
http://www.ft86club.com/forums/showthread.php?p=1920724
Old 02-02-2020, 10:29 PM   #35
Originally Posted by tomm.brz View Post
[MENTION=87905]Could be the variator that needs to be changed? is that spool valve part of it?
I am figuring out how to log using techstream. The UI is not quite... Well, it sucks.
When you say variator, could it be what I understand is called the phasor?
Old 02-02-2020, 10:52 PM   #36
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
I've experiencing non-moving AVCS issue also after repairing rocker arm exodus. When disabled, intake cams are not moving even in the Active Test of Techstream, but exhaust cams moving. Both are not moving in the Tactrix OP2 logs.
But after doing repeated engine braking, finally it works again. Like driving pattern for P000A, P0011, etc.
But don't know how long it takes whenever new map is loaded. Just keep doing above driving pattern until cams are moving.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following 5 Users Say Thank You to makinen For This Useful Post:
Compelica (02-04-2021), DarkPira7e (02-03-2020), JIM THEO (02-03-2020), tomm.brz (02-03-2020), Ultramaroon (02-02-2020)
Old 02-02-2020, 11:40 PM   #37
Originally Posted by makinen View Post
Hi,
Attachment 184550
I see that fuel cut when decelerating in region-D is emphasized. Without knowing exactly what does what, it still makes sense. I've noticed that, at no matter what RPM, in fuel cut (mode 4) the VVT angles lock to zero. The intake phasors have a spring-loaded zero lock. The exhaust phasors do not.
Old 02-02-2020, 11:56 PM   #38
tomm.brz
Yes sorry, i meant that
i bent that cam and mechanic assumed that from the shock, i needed to change also the 2 chains and other things correlated to them, but not the phasor.. but now i d really preferred to have changed it
Ultramaroon (02-03-2020)
Old 02-03-2020, 12:09 AM   #39
I have one phasor that flutters too but I can only see it with tactrix sample rates. Unfortunately no one has the aim angle (input) parameters for tactrix definition files. Tonight I am trying to figure out how to get higher resolution from techstream.
Old 02-03-2020, 12:12 AM   #40
tomm.brz
i have techstream, i mean i ll just have to find again a cheap adaptor because for now all I have is ecutek but i'll do.
As Ultramaroon said its user interface is frustrating, can you help us find this thing we are talking about in it?
I read somewhere here in the forum that people needed to change the ecu because it stored wrong initial position values.. doesn t the ecu reset the value after a reset or. flash?
Old 02-03-2020, 12:17 AM   #41
tomm.brz
well ecutek is not so bad in refresh rate? i get 12 hz with bluetooth and around 40-50hz with cable and proecu, and i see the flutter real time
Old 02-03-2020, 12:19 AM   #42
It is true. The initial position value table can only be updated when the VVT system is judged to be "OK." The problem is when the root cause for the initial position value drift is corrected, the bad value in the table forces a large enough error between commanded and measured angles to throw the "not OK" flag. It can never re-learn.
Edge Insight CS Monitor (1996 & Newer OBDII Enabled Vehicle) FBPARTS Exterior Parts - The Rest 3 12-02-2015 04:08 PM
Album art enabled but not displayed (bespoke)? Mexibeetle Electronics | Audio | NAV | Infotainment 7 01-22-2013 09:39 PM
