Old 01-30-2020, 04:52 PM   #15
radroach
Drives: car
@haute idle dip and partial stall / lights flicker was a problem I had when I had an ABS / CEL light for a broken ABS module, throwing me in limp mode.
This was on manual transmission though. Interesting that yours isn't throwing a CEL.
Maybe time for a diagnosis at the dealership! Also, try to get a video of the problem sometime, preferrably with somebody else filming while you're at the wheel.
Old 01-30-2020, 10:14 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by ROFL it's Waffle View Post
Sorry, not sorry.. Stop doing this, your transmission is designed to brake in drive.
https://mechanics.stackexchange.com/...hing-stops-bad
yes, but it is an important way to verify the motor will stay running if it's not in gear.
also, there is absolutely nothing in your link that says that it is fundamentally damaging to the vehicle to put it into neutral while stopping. mostly just speculative 'what-ifs' about some rogue snow cone truck traveling at mach 1 into the back of you at a stop light, on the one-off chance you're first in line at a light and can do anything about it.
Old 01-31-2020, 03:02 AM   #17
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
I always thought it was because putting it in neutral wastes gas. On a fuel injected engine, whenever you let off the gas to slow down, the ECU can cut fuel completely to aid in fuel savings and engine braking. By putting the car in neutral, the ECU has to keep the engine running since there is no inertia carrying it along from the car slowing down. So you waste gas by putting it in neutral... if gas savings are what people are looking for.
sly is offline   Reply With Quote
Old 01-31-2020, 09:44 PM   #18
soundman98
soundman98's Avatar
i've always found that argument interesting as well. it's technically correct. but then if the primary motivation is to 'save gas' then it should be reasonable under the same circumstance to blow through all stop lights to avoid altering speed too much to make the most use of the gas.
sly (01-31-2020)
Old 01-31-2020, 09:52 PM   #19
sly
sly's Avatar
That would save on brakes too!
The Following User Says Thank You to sly For This Useful Post:
soundman98 (01-31-2020)
weird situation zizon93 BRZ First-Gen (2012+) — General Topics 30 09-19-2017 10:30 PM
San Jose cop situation help taylorsankey Northern California 33 08-17-2014 01:45 PM
Tire situation jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 11-06-2013 05:55 PM
My situation MR WHAAKAKA Scion FR-S / Toyota 86 GT86 General Forum 31 05-22-2013 04:14 PM
