#29 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I'm asking because I don't know. Sounds like your car was tuned on a dyno in a shop. I guess I thought you would have an OFT in your possession (which would have all the information we're asking about), even just for the convenience if you need to change maps.
#30 |
Drives: jrsc_brz
im not even going to read all the posts, just the OP. get a JRSC c30. its what everyone has. watch speed academy videos on youtube if you wont take it from me.
and read this quick article if ur serious abt changing FI types, take the 60 seconds and read the dang thing: http://speed.academy/scion-frs-subar...install-guide/ |
#31 | |
JDM Vaping Stance Nation
Drives: 2013 White
Usually OFT is for people who do E-Tuning without a Dyno Shop since most places aren't familiar with OFT. You also can't lock your tune with OFT either, which most tuners want to.
Clueless
#32 | |
Drives: 2017 Subaru BRZ
Sent from my SM-G960W using Tapatalk |
| The Following User Says Thank You to j_ros94 For This Useful Post: | ROFL it's Waffle (01-29-2020) |
#33 | |
Drives: 14 BSP Edelbrock BRZ
| The Following 4 Users Say Thank You to toast For This Useful Post: |
#34 | |
#35 |
Drives: brz 2017 hksv2
i too think it s a downgrade going to supercharger, you would soon regret it
Also a sc maybe won't give you the extreme heat soak of the turbo, but it still suffer immensely the heat, like a huge torque/drop when the ambient temperature rise, and the car is always dead under 4k rpm |
| The Following User Says Thank You to tomm.brz For This Useful Post: | j_ros94 (01-29-2020) |
#36 |
Drives: Q5 + BRZ + M796
I agree with others that a supercharger is a torque curve downgrade, and it is likely not necessary because your turbo issues should be fixable. People run turbos in far hotter conditions and climates. Either the AFR is way off or the turbo has damage to the fins/shaft or there is a melted cat causing an obstruction or the thermostat has failed. I don’t know, but this is fixable.
I just realized I never told you how to tell if the thermostat is stuck. One way is to remove it and replace it, but to confirm it is bad, you boil the thermostat in water and see if the copper plunger opens. If it maintains its size then it is old and frozen. A stuck thermostat usually causes an engine to run hot or run cool. If your engine is running hot, but your radiator cap is cool to the touch then that is a tell tale sign that the thermostat is stuck.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | j_ros94 (01-29-2020) |
#37 | |
Rust bucket enthusiast
When you're moving at speed I doubt it'd present an issue |
#38 | |
#39 | |
2013 Series 10 FRS #553
#40 |
I am with most everyone else. The heat issue is fixable. Also going supercharger is a downgrade in reliability. The heat needs to stay inside the exhaust. This can be done with ceramic coating and/or wrapping. Turbo blanket is a must. Everything should be covered up to the turbo. Since you are having heat issues you will probably want to cover after turbo all the way to the over pipe. You will probably need to add some hood vents also to get heat out. I went with 2 of the Versus large vents. My setup is similar to yours. Intercooler, oil cooler, radiator. I have the AVO kit. The design is better for heat control. My inlet was moved fwd of the intercooler with the Greedy intake. I sit in Dallas traffic in 100+ deg weather with the A/C on and do not have heat issues. Hottest track day I have done is in the 70’s and did not have a heat issue.
Cliff note version. I believe wrap will cure your issue, vent just to be sure. |
#41 | |
#42 | |
I Love custom Turbo kits
Drives: Limited BRZ
It seems to me your only problem here is the fans are not pulling the amount of air needed in stop and go traffic to cool your engine down. That or you have issues with your cooling system, air bubble/leak/stuck thermostat/bad water pump among others.
| Wtb turbo / supercharger kit | Sloyota | Want-To-Buy Requests | 0 | 02-28-2019 03:15 AM |
| HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit | Ogremair | Forced Induction | 27 | 09-10-2015 05:39 AM |
| Looking for a turbo or supercharger kit!! | Anthony7515 | Want-To-Buy Requests | 11 | 05-16-2014 09:25 AM |
| HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 12:50 PM |
| Looking for a Frs for R&D on a turbo and supercharger | Toxic | Forced Induction | 38 | 10-23-2012 04:13 PM |
