Old 01-26-2020, 04:31 PM   #309
Evil Rocky
Drives: FRS
I already purchased my k24 and soon my s2000 Transmission.
Removing turbo and engine in Fen or March and excited for this. Will have a bunch of pic soon. Will work on buying motor mounts, oil pan from Pure Motorsports.
Evil Rocky is offline   Reply With Quote
The Following 2 Users Say Thank You to Evil Rocky For This Useful Post:
Irace86.2.0 (01-27-2020), Pure Automotive (01-27-2020)
Old 01-27-2020, 11:39 AM   #310
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Shifters are getting close also, still tweaking some design stuff but they are essentially figured out
Pure Automotive is offline   Reply With Quote
The Following User Says Thank You to Pure Automotive For This Useful Post:
Old 01-27-2020, 12:09 PM   #311
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Pure Automotive View Post
UPDATE!!
-After consideration of a lot of factors, we have decided to go with a modified steel stamped pan. The pan will be steel, designed to clear the 86 cross member using our K Series mount kit.
Does the use of the steel pan change the positioning of the engine in the bay compared to when the aluminum pan was originally being considered?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Old 01-27-2020, 01:25 PM   #312
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Good question, but I doubt it, or they would likely have to change the engine mounts and the headers they have already designed/sold, yet it is possible.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
venturaII (01-27-2020)
Old 01-27-2020, 01:40 PM   #313
venturaII
venturaII's Avatar
Yeah, I was assuming the same, but it's worth asking at any rate.
Old 01-27-2020, 03:13 PM   #314
Pure Automotive
No, it was literally a matter of cost. The shape was/is identical. I started to do aluminum and the end result was going to be something that costs $800+ with a baffle, and would require different mounting hardware than what comes with the stock K24, and they take 3x as long to make etc. With the steel pans, we can pump them out quicker and the end result is going to be a sub $600 pan and baffle combo that accomplishes the same thing. I'll be the first to admit, they're nothing fancy, but the whole point of this swap since day 1 has been to make it "cheaper than 2J and LS".
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
Irace86.2.0 (01-27-2020), pgranberg11 (01-28-2020), venturaII (01-27-2020), wparsons (01-28-2020)
Old 01-27-2020, 04:43 PM   #315
venturaII
venturaII's Avatar
Thumbs up
No, it was literally a matter of cost. The I'll be the first to admit, they're nothing fancy, but the whole point of this swap since day 1 has been to make it "cheaper than 2J and LS".
That is the right answer. I could care less that the pan looks like...as long as it holds oil and doesn't look like someone made it with a lump mallet.. Function first.
Old 01-27-2020, 05:36 PM   #316
Pure Automotive
I just composed a list of all the parts we sell and a couple we don't sell yet, all of which I think are "essential" to a true bolt in K24 Swap. Every single part on the list is something that you can put together and install in the car without any cutting, beating, welding, or fabrication of any kinda. I may have missed a couple small things but this is like 95%. This is not an official quote or anything, totally just for those of you who may not know what all goes into a swap. As I said before we don't sell everything on this list (yet) but we do sell the majority of it on swapyour86.com
Mount Kit $499.95
Oil Pan / Baffle $575.00
Type S Oil Pump and Parts $350.00
Intake Manifold $799.99
Throttle Adapter $72.99
Throttle Body $379.99
Fuel Rail $179.95
Injector/Sensor Bundle $1,299.00
S2K Shifter $589.95
Trans Adapter Plate $349.95
Adapter Flywheel $529.95
Clutch Kit $725.00
Motec Kit $5,595.00
Header $1,695.00
JDM K24 $750.00
S2000 Trans $750.00
Fuel Fittings $200.00
CoolantAdapters $275.00
Driveshaft $900.00
Water Pump Kit $699.00
B Series Alternator $150.00
Custom radiator hoses $150.00
Total $17,515.72 IN PARTS
Sounds like a lot when you put it all together, but this list is enough for a 100% bolt in and started up NA car that makes north of 230whp and loses 100 lbs over stock. If anyone wants to ship me a their car, email me, we will be doing turn key swaps for these effective immediately!
The Following 8 Users Say Thank You to Pure Automotive For This Useful Post:
Drifter X (01-28-2020), DustinS (01-28-2020), Evil Rocky (01-28-2020), Irace86.2.0 (01-27-2020), Jdmjunkie (01-27-2020), Jmk91 (02-06-2020), Joesurf79 (01-31-2020), Jyn (02-10-2020), wparsons (01-28-2020)
Old 01-27-2020, 08:10 PM   #317
djliquidsteele
Drives: Scion FR-S
Can heat and A/c be retained as well?
djliquidsteele is offline   Reply With Quote
The Following User Says Thank You to djliquidsteele For This Useful Post:
Old 01-28-2020, 11:22 AM   #318
Pure Automotive
As with all of our swaps, factory heat and AC will work. It requires making 2 heater lines to connect to the factory heater core, and modifying the factory AC lines to connect to an AC compressor. With the setup I explained above, it deletes the AC compressor. All you would need to do is figure out an accessory belt routing to include an AC compressor. We chose not to do that for this initial setup because getting the main components is more important than AC for now.
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
djliquidsteele (01-28-2020), wparsons (01-28-2020)
Old 01-28-2020, 02:47 PM   #319
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
oh my god. i'm so glad this is basically done. we will see how long my turbo BRZ will last this gridlife season in TA. as soon as the motor goes, time to go all in with a turbo kswap. thanks for pushing the development with this!
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
Pure Automotive (01-29-2020), wparsons (01-28-2020)
Old 01-30-2020, 06:15 PM   #320
Pure Automotive
https://www.facebook.com/SwapYour86/...3912052554670/
https://www.facebook.com/SwapYour86/...4865739393482/
https://www.facebook.com/watch/?v=2495175090700598
gtengr (01-30-2020), Jdmjunkie (01-30-2020), Joesurf79 (01-31-2020)
Old 01-31-2020, 02:22 PM   #321
Pure Automotive
Important info for those concerned about weight and balance!
Stock BRZ manual curb weight is posted as 2798. We ended up at 2615! Not bad!
The Following 6 Users Say Thank You to Pure Automotive For This Useful Post:
Code Monkey (01-31-2020), DustinS (01-31-2020), gtengr (02-02-2020), Irace86.2.0 (02-04-2020), Tokay444 (02-04-2020), venturaII (02-05-2020)
Old 01-31-2020, 09:51 PM   #322
wparsons
wparsons's Avatar
Love everything about it, except the sound. Worth it for the lower weight, better power, and better reliability though!
flickr
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 02:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 12:57 PM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:49 PM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:23 PM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 07:33 PM
