Old 01-23-2020, 04:19 PM   #15
pher.da.rico
Drives: 2018 Premium Black silica BRZ
My pleasure! What are we replacing? I recommend not worrying about the slave cylinder unless it gets really soggy around the rubber dust cover over the end. I don't think that anything is wrong with it.
So I was gonna replace the slave cylinder
But if that might not be a problem should I bleed the clutch ?
pher.da.rico is offline   Reply With Quote
Old 01-23-2020, 05:06 PM   #16
pher.da.rico
Also there is some gunk/residue on the slave cylinder
Old 01-24-2020, 02:46 AM   #17
Meh. Slave cylinder is cheap. Of course it will need bled if you open the system but it's really easy.
Old 01-30-2020, 07:07 PM   #18
pher.da.rico
Hey so I changed my slave cylinder and bled my clutch and replaced it. everything is good. The only thing is when I press in the clutch and rev up my rpms there’s STILL a clunk sound from the front half of the car. Does anyone know what this could be
Old 01-30-2020, 11:08 PM   #19
No idea. Post a recording of the sound to youtube. Try to capture a decent example.
Old 01-31-2020, 06:58 AM   #20
cueball89
Drives: 15 Impreza
It's grease from the slave cylinder piston and clutch fork. Clean the area and if it doesn't come back its grease. If it comes back your slave cylinder is leaking. I'd also recommenced re-greasing this pivot point with a higher temperature grease.
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
pher.da.rico (02-08-2020)
Old 02-07-2020, 03:42 PM   #21
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
Pro tip: don't Google image search the thread title.
BigHugeFatGuy is offline   Reply With Quote
The Following User Says Thank You to BigHugeFatGuy For This Useful Post:
SuperTom (02-12-2020)
Bad tranny Retrorv Issues | Warranty | Recalls / TSB 16 10-16-2018 07:50 PM
Looking for 86 A/T Tranny Soloside Want-To-Buy Requests 0 03-10-2017 10:45 AM
STI JDM tranny mount vs Perrin tranny support NVH khrono Engine, Exhaust, Transmission 2 03-15-2016 09:43 PM
Tranny to Driveshaft Oil Leak BDotG Engine, Exhaust, Transmission 3 09-07-2015 12:05 PM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 07:53 AM
