Old 12-27-2019, 03:50 AM   #1
aznchris
Drives: Scion 86 tS
Chinese speed/auto lock module blinking hazard issue
I bought a auto/speed lock module for my AT FRS and although it works as advertised, it flashes my hazards every time a door or the trunk is opened. It's quite annoying to me. I was wondering if anyone else had this same module and knows how to disable it. I contacted the seller and they sell to do N-R (3x), but it didn't work. Tried multiple times too. I was wondering if anyone else had any luck or maybe knows how to mod one?
aznchris is offline   Reply With Quote
Old 12-28-2019, 01:09 AM   #2
davidmcl
Drives: 2013 BRZ supercharged
Same here. It is apparently a designed safety feature. I think maybe something related to carjacking?
davidmcl is offline   Reply With Quote
Old 12-28-2019, 01:26 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Simple. Uninstall it.
Problem solved.
Buy a different unit, one that doesn't have that annoying feature.
Old 12-28-2019, 01:49 AM   #4
aznchris
Drives: Scion 86 tS
Imagine me carjacking my own car every time? lol
Problem solved.
Unfortunately I could only find this one that was reasonably priced at like around 20 bucks. The trac box from seriesblueadventures is like 140 and comes with a bunch of extra things that I don't need. I also tried the DIY one from this forum, but for some reason I couldn't get it to work. Tried so many different boards and troubleshoots for the DIY, but to no avail.
Old 12-28-2019, 08:35 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
sometimes the best option is to not be cheap about it.
Old 12-28-2019, 10:30 AM   #6
gpvecchi
gpvecchi's Avatar
I have the Kiramek JDM module, it works flawlessly, the only annoying thing is that for a MT car you have to unlock with handbrake or button, it doesn't unlock with engine off...
Old 12-28-2019, 10:51 AM   #7
aznchris
Drives: Scion 86 tS
Oohh. I've seen their website. Wouldn't it not matter for M/T that you have to use the handbrake? I mean like uuuuusually you'd pull it before turning off the car right? Too bad it doesn't work for my pleb key turning A/T ): also if it was still available too expensive for me T.T
This got me thinking.. what if I got an adapter, cut the 12v wire from the device side and then just wire the device side to ignition switch. Can't flash my hazards if it doesn't have power lol. Ultimately tho still hate the blinks.
Old 12-28-2019, 10:58 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Educate me, what is it? What's it supposed to do?
Old 12-28-2019, 11:27 AM   #9
aznchris
Drives: Scion 86 tS
It's an obd2 module that auto locks your door on D gear or 10 KM/h for M/T. Auto unlock your doors on engine off. Has a side function of flashing your blinkers when doors or trunk is open. And for some reason I suspect it will turn on blinkers under hard braking from at least 50mph, but it hasn't happened for me so either I'm not braking hard enough or I'm wrong.
Old 12-28-2019, 11:31 AM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Aahh.. okay, my car (MT) has automatic door locking when the clutch is released and unlocks when in neutral.. but don't have the auto blinking.. I thought this was standard on all Twins.
Old 12-28-2019, 11:45 AM   #11
Grady
Grady's Avatar
Isn't there a switch on the door you can hit with you finger?
Old 12-28-2019, 02:27 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep, and you can hit it with anything you like, not just your finger..
Old 12-28-2019, 10:00 PM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This seems like a waste of the obd2 port. I'm surprised this can't be done with software or some rom edits, or a splice that doesn't require being constantly plugged into that port...
Old 12-29-2019, 12:27 AM   #14
aznchris
Drives: Scion 86 tS
I'm surprised too, but there's nothing that I know of. I mean you could always get a splitter too, but the trac box doesn't plug into obd. It supposedly plugs into a connector behind the HU? Idk how that works. Carista doesn't have the open either. I doubt OFT has an option. Idk what else ):
Turn Signal/Hazard Lights Issue Kutchak Issues | Warranty | Recalls / TSB 8 01-02-2022 09:25 PM
LED Bulb Change - Hazard Issue Kodename47 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-01-2017 03:10 PM
BRZ jammed window issue/blinking auto light? Superhatch Issues | Warranty | Recalls / TSB 28 02-15-2015 05:45 AM
