Drives: Scion 86 tS
Chinese speed/auto lock module blinking hazard issue
I bought a auto/speed lock module for my AT FRS and although it works as advertised, it flashes my hazards every time a door or the trunk is opened. It's quite annoying to me. I was wondering if anyone else had this same module and knows how to disable it. I contacted the seller and they sell to do N-R (3x), but it didn't work. Tried multiple times too. I was wondering if anyone else had any luck or maybe knows how to mod one?
#2 |
Drives: 2013 BRZ supercharged
Same here. It is apparently a designed safety feature. I think maybe something related to carjacking?
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Simple. Uninstall it.
Problem solved. Buy a different unit, one that doesn't have that annoying feature.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 | |
Drives: Scion 86 tS
Unfortunately I could only find this one that was reasonably priced at like around 20 bucks. The trac box from seriesblueadventures is like 140 and comes with a bunch of extra things that I don't need. I also tried the DIY one from this forum, but for some reason I couldn't get it to work. Tried so many different boards and troubleshoots for the DIY, but to no avail. |
#5 |
ProCrastinationConsultant
sometimes the best option is to not be cheap about it.
#6 |
I have the Kiramek JDM module, it works flawlessly, the only annoying thing is that for a MT car you have to unlock with handbrake or button, it doesn't unlock with engine off...
#7 | |
Drives: Scion 86 tS
This got me thinking.. what if I got an adapter, cut the 12v wire from the device side and then just wire the device side to ignition switch. Can't flash my hazards if it doesn't have power lol. Ultimately tho still hate the blinks. |
#8 |
Drives: Subaru BRZ
Educate me, what is it? What's it supposed to do?
#9 |
Drives: Scion 86 tS
It's an obd2 module that auto locks your door on D gear or 10 KM/h for M/T. Auto unlock your doors on engine off. Has a side function of flashing your blinkers when doors or trunk is open. And for some reason I suspect it will turn on blinkers under hard braking from at least 50mph, but it hasn't happened for me so either I'm not braking hard enough or I'm wrong.
#10 |
Drives: Subaru BRZ
Aahh.. okay, my car (MT) has automatic door locking when the clutch is released and unlocks when in neutral.. but don't have the auto blinking.. I thought this was standard on all Twins.
#12 |
Drives: Subaru BRZ
#13 | |
This seems like a waste of the obd2 port. I'm surprised this can't be done with software or some rom edits, or a splice that doesn't require being constantly plugged into that port...
#14 |
Drives: Scion 86 tS
I'm surprised too, but there's nothing that I know of. I mean you could always get a splitter too, but the trac box doesn't plug into obd. It supposedly plugs into a connector behind the HU? Idk how that works. Carista doesn't have the open either. I doubt OFT has an option. Idk what else ):
| Turn Signal/Hazard Lights Issue | Kutchak | Issues | Warranty | Recalls / TSB | 8 | 01-02-2022 09:25 PM |
| LED Bulb Change - Hazard Issue | Kodename47 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-01-2017 03:10 PM |
| BRZ jammed window issue/blinking auto light? | Superhatch | Issues | Warranty | Recalls / TSB | 28 | 02-15-2015 05:45 AM |
