Old 12-17-2019, 09:35 PM   #29
HaXx
Drives: jrsc_brz
Originally Posted by 86MLR View Post
No respectable exhaust builder would concider designing a UEL header, unless it is for packaging.
babyyoda still want uel header
kidding aside you make great points about el vs uel that i had not known prior to your post, packaging etc.
some still want to be in the uel boxer community more than they want 10hp tho
im still oe header tho so dont shoot me, i can just see both sides.
HaXx is offline   Reply With Quote
Old 12-17-2019, 09:48 PM   #30
86MLR
86MLR's Avatar
Hey, don't get me wrong, I'm a victim of packaging.
When I went looking for boost, the package I liked best, and which fitted my power goals, was the AVO, which damn it, has an UEL header.
There were other options out there, but most had the turbo up high infront of the radiator, IMO they had a better header design, but the AVO just looks much more stealthy.
So yeah, packaging compromise
When I was NA I tried the Tomei header vs the OEM decat, that was a waste of $900AUD, the decatted OEM out performed the Tomei, everywhere.
Most importantly is don't fall into the whole UEL header and extra torque hype. The conversations and actual gains are painfull.
As always: Opinions may vary
Old 12-18-2019, 11:03 AM   #31
Denver20
Drives: 2002 WRX
Originally Posted by Lincoln Logs View Post
I'd agree with others that if you have access to E85 and you are not on a race track one a month doing an HPDE, stock header.
This dyno is a comparison of running E85 with a factory 2017 header vs running a UEL header. There was less of a difference with the version 4 tune on a stock header.
This chart shows the stock header and differences between the v3 and v4 tune, you can see most of the mid-range bump came from that.
That’s correct
Denver20 is offline   Reply With Quote
Old 12-21-2019, 12:27 AM   #32
jflogerzi
jflogerzi's Avatar
Just try an OFT first. If you have regular e85 then ecutek+ tune + flex fuel is all you need.
2013 Series 10 FRS #553
Old 12-22-2019, 01:26 AM   #33
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Agree with this. Start small then build your way up. It would be great if you had access to e85, but start with the tune to help that dip if you’re scared to go catless. While you feel out the tune, you can do other mods to help the car’s performance like lightweight wheels, good tires, lighter exhaust, a drop-in filter etc. Punching out your cat is an option, but I personally would buy a catless header and swap out to stock when emission time comes just in case they want to give you shit about it. Whatever the case may be, you’ll be safe with a completely stock header. There’s lots of options when it comes to headers so you can make your own choice on that
Will BRZ is offline   Reply With Quote
Old 12-22-2019, 08:48 AM   #34
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Thanks jflogerzi and Will_BRZ! I'm going to do just that.
My read of the state emissions regulations doesn't detail the exact form of testing that's done. But when I brought my other car (2015 Mustang GT) for its emissions inspection, they did a tailpipe test. It could just be specific to my community, but after that, I'm leery of trying to get through without a cat (and also don't want to go through the headache of swapping headers for every emissions test; the more messing with the engine, the greater the chance for something to break).
I've read a lot about the benefits of E85, but unfortunately, it's hard to find in my area.
Thanks again!
AnalogMan is offline   Reply With Quote
Old 12-23-2019, 07:20 AM   #35
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Thanks again!
They do a tailpipe test. Mass is evil. They even rev the engine up etc, it is all awful. Plus they attach the computer to the car and are vile horrible things. It is best just to run and move somewhere without an income tax or a car inspection.
The best thing to do is find an independent mechanic that you like that does the testing and just grow a relationship. That way if they like you they will look the other way if they can, and honestly tell you when they cannot. There are lots of good people that happen to do tests. There are also lots of assholes that don't give a shit that are using broken outdated decades old equipment that want to fail you.
why? is offline   Reply With Quote
Old 01-07-2020, 10:33 PM   #36
Danny318
Drives: 2019 BRZ
This is not true. There has not been tailpipe testing in MA for more than 10 years. They scan for OBD2 codes (check engine light) and that's it for emissions.
Danny318 is offline   Reply With Quote
Old 01-07-2020, 10:40 PM   #37
jflogerzi
jflogerzi's Avatar
Lucky... Wish we had that in CA
Old 01-08-2020, 09:46 AM   #38
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
It's also not true that you can ask a buddy who has an inspection station and get a mail-order sticker. Only an idiot, or someone who doesn't care about losing his inspection license, would do that today. Mass inspection stations have something like 13 cameras scattered around the inspection bay, including at least one on the operator, recording the entire inspection process. If there's ever any question about the sticker on your car, the state goes back and pulls those records, and if fraud is determined, there goes your easy and guaranteed inspection income...
That being said, if you install a header and/or flash the tune, as long as there are 1) no codes being thrown, and 2) not a bunch of OBD log parameters turned off, they will never even bother opening the hood.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 01-08-2020, 10:05 AM   #39
J1Avs
Drives: 2018 BRZ tS
I ran a JDL Catted UEL and JDL UQ FP/OP combo pipe on 93. I made 194whp and 155ftlbs on a DynoDynamic Dyno with a custom tune.
Stock usually runs around 160-165
You can run clean, and still make good power. E85 is nice, but it's also more difficult to come by, and given you are in New England, it SUCKS in the cold. Also given this map (which isn't 100% accurate): https://afdc.energy.gov/fuels/ethano...arest?fuel=E85 there are not a whole lot of locations in NE, unless you happen to be in of the very few areas.
JDL just re-released some catted headers. I'd recommend checking them out and going from there. I never threw a code, and never had any sensors disabled.
J1Avs is offline   Reply With Quote
Old 01-08-2020, 10:24 AM   #40
StraightOuttaCanadaEh
Wes
Was the front pipe the catted one or just resonated?
Instagram: @gt86ws
Old 01-08-2020, 10:26 AM   #41
J1Avs
Drives: 2018 BRZ tS
The Ultra Quiet from JDL is both Catted and Resonated
Old 01-08-2020, 10:48 AM   #42
Wes
even more impressive then that you gained 30 hp. Usually that's the expected gain from a fully catless setup
Instagram: @gt86ws
Join us for Gizdich Ranch Pie Run 7 (2019) -- Sat Aug 17, 2019 PMok Northern California 11 08-20-2019 11:17 PM
2019 Fiesta ST or 2019 Subaru BRZ korhun BRZ First-Gen (2012+) — General Topics 97 08-02-2019 08:56 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 12:05 PM
Is 75% tint worthwhile? (PA) nalc NY / NJ / CT / PA 10 07-31-2013 04:13 PM
Earth Harness Systems, Worthwhile or not? Panman Engine, Exhaust, Transmission 5 04-23-2013 05:32 PM
