Old 12-16-2019, 10:58 AM   #57
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by PenGun View Post
My BRZ is not great in the snow, its so light.
But my Suzuki Samurai is lighter and I hardly ever put it in 4 wheel. Its quite different with big tires and not much air in em', as they are supposed to be. 20 lbs is the law with a Sammy.
I thought the Suzuki was always 4WD, low gear set when things got really tricky for the little thing..
Old 12-16-2019, 11:03 AM   #58
Jordanwolf
Rice King
Jordanwolf's Avatar
As far as I know, most if not all 4WD vehicles have the ability to turn off the 4WD and go to 2WD, unlike an AWD system.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 12-16-2019, 11:11 AM   #59
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
4wd and awd are two very different animals.
Old 12-16-2019, 11:15 AM   #60
That is indeed the definition of the difference between "4WD" and "AWD". Technically all AWD vehicles are 4WD but in order to market the difference they sort of split them.
I believe that the 4WD/AWD split was sort of established back in the day when to switch over your 4WD vehicle you had to stop, get out, lock on the front hubs and then get back in and drive. That process of course went away with the automatic or electronic systems but the definition stayed.
Old 12-16-2019, 11:16 AM   #61
How so? Both have 4 wheels that propel the vehicle.
Old 12-16-2019, 11:25 AM   #62
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Traditional 4wd with transfer case, where front and rear axles are locked is only to be used on slick surfaces. There is no slip in the system and requires the slip of the ground. Driving them in 4wd on dry pavement will ruin them.
Awd systems have slip units between front and rear drives. Huge difference.
And auto locking hubs suck. They stick all the time, and are weaker than manual locking hubs. First thing serious 4x4 people do is swap to manual locking hubs.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
gravitylover (12-18-2019), soundman98 (12-16-2019), Ultramaroon (12-16-2019)
Old 12-16-2019, 12:01 PM   #63
Then there's the in-between. My Suburban has 2WD, Auto 4WD, 4WD High and 4WD Low.
I've always found the Auto 4WD the best for the mess we get around Atlanta unless it's hop deep and I know I'm crawling.
Dadhawk is online now   Reply With Quote
RToyo86 (12-16-2019)
Old 12-16-2019, 12:03 PM   #64
Jordanwolf
Rice King
Jordanwolf's Avatar
Well I'd assume the use of High and Low would be specific to when you happen to be in a bit of a pickle.. (stuck or something)
Glorious Honda.
Old 12-16-2019, 12:04 PM   #65
JD001
JD001's Avatar
Drives: Subaru BRZ
^^^^^ Glad we're all sorted on different drives ^^^^^
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Dadhawk (12-16-2019), Jordanwolf (12-16-2019)
Old 12-16-2019, 12:29 PM   #66
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
My old 5spd AWD Suzuki sx4 had a clutch based center diff for the AWD. It had a 2wd/auto and 4WD lock for sticky situations that would disengage at 30kmh or so.
That thing was a tank for what it was when you had good winter rubber on it. I plowed through snow that was at license plate level just below the headlights and it took it like a champ.
This car is no wear near as capable but beyond crazy snow storms of that caliber I managed just fine every day last season except for one.
The car dragged it self out of this mess with out much fuss. Some revs in reverse and about 20-30 seconds. Compared to a coworker with a genesis which spent 40 minutes to do the same.
The Following User Says Thank You to RToyo86 For This Useful Post:
JD001 (12-16-2019)
Old 12-16-2019, 01:05 PM   #67
JD001
JD001's Avatar
Drives: Subaru BRZ
I wonder if there was s big "hoo-ha' when manufacturers switched from manual to automatic drivetrain locking?? I can picture it now, manual 4WD with back window graphics warning other drivers that the car ahead of them is manual and therefore prone to erratic behaviour!!
soundman98 (12-16-2019), Tcoat (12-16-2019)
Old 12-16-2019, 01:37 PM   #68
I think that most 4WD now have an auto setting.
Old 12-16-2019, 02:03 PM   #69
Yea, probably so. It wasn't when mine was built in '04. There are some trims that don't have the "auto" button.
Old 12-16-2019, 05:37 PM   #70
PenGun
Drives: Red 2019 Subaru BRZ
LOL. My 87 Sammy is a beast. It goes anywhere I'm brave enough to take it. One advantage real 4WD has is that the axles run slightly different ratios. Effectively the vehicle is pulled apart when in 4 wheel. Smooths out the rough stuff.
As it is extremely short, light, and has massive tires, for its size, at low pressure it seldom actually needs 4 wheel. We had pretty god snow last winter and it never saw 4 wheel, for snow, at all.
PenGun is offline   Reply With Quote
First Driving Experience in the SNOW!! Lync Scion FR-S / Toyota 86 GT86 General Forum 51 01-22-2016 12:19 PM
How much snow is too much? Guelph/London/ Barrie driving? rpvnwnkl CANADA 26 10-31-2015 06:29 PM
Snow and Ice Driving RedFRS4me Northwest 25 02-11-2014 11:35 PM
I Spent the Weekend Driving my FR-S in Snow - Insight SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 49 11-16-2012 05:56 PM
Driving experiences in the snow jmathew8130 BRZ First-Gen (2012+) — General Topics 8 11-16-2012 12:14 AM
