#281 |
#282 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (11-20-2019) |
#283 | |
The Dictater
Drives: '13 Red Scion FRS
Some of the fun bits: Inhaling it has been known to cause suffocation, and prolonged exposure can cause severe tissue damage. It's also extremely corrosive and discarded quantities do millions of dollars in damage to infrastructure every year. Due to not being a controlled substance, some ingest it in small doses to enhance performance. There's no test for it, so anyone could be on it and you wouldn't know. |
| The Following User Says Thank You to Spuds For This Useful Post: | humfrz (11-20-2019) |
#284 | |
![]() ![]() ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Spuds (11-20-2019) |
#285 |
Only users lose drugs.
Drives: All the time
I have a hydrofluoric acid story from back in the early 80's...I was just a dopey high school kid washing cars at the local VW dealership, and our equally dopey chemical supply delivery guy dropped off a 5 gallon pail of the stuff one day and said "Here, try this.. it works AWESOME on dirty wheels, but be sure to dilute it a bit..." End of safety lecture.
It DID work like gangbusters on otherwise hopelessly grungy aluminum wheels, but man, it was some harsh stuff... No protective gear at all, mixed anywhere from 2:1 and stronger, and applied with a spray bottle...mist everywhere, all over our hands, fumes were chokingly strong, etc. It wasn't until I was in college and my organic chem instructor was talking about how bad it really was, that I realized I'd once again narrowly missed the Darwin hammer...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 3 Users Say Thank You to venturaII For This Useful Post: |
#286 |
Drives: '12 C63 P31, '23 GRC
I'm confused how anyone is going through brake pads that quickly. Unless they're doing Tail of the Dragon mountain runs daily (or track their car with stock pads - which is just dumb).
Also those rotors look horrendously bad. Also also, I'm waiting for someone to tell me how they check pad depth for the inner pad on any car without removing the wheels (or lifting the car into the air). It's impossible. And IME it's usually the inner pads that are thinner from use. ![]() ![]()
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#287 | |
Drives: Subaru BRZ
#288 |
^perhaps. All I know is I sure as hell wouldn't admit that I wear out my pads in less than 30,000 miles.
#289 |
Site Moderator
Drives: Stuff
I’ve worn out pads within a few hundred miles.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#290 | |
Years ago I scolded an artistic friend when I found out that she had started dabbling in etching glass with the stuff. Yikes!
#291 |
Mechanix gloves have a purpose, and so do nitrile gloves.
If you don't know the difference, try doing more than debadging cars with floss tools. Pit crew comment was hilarious! Get some new wheels, camber boy. Brake pads? Jack car. Remove wheels Remove caliper. Remove pads. All done with thick gloves. Only step I removed the gloves was to replace the shims. The other use for cloth gloves is anything that involves grease, oil, lube. Hassle to keep changing nitrile. I have 5 pairs of Mechanix and wash each pair after use. |
#292 |
By the way, with new thick pads, I can not see the pads from the outside of the wheel.
So, it was not just a case of low brake pads. Just a crap covered design |
#293 | |
#294 |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 01:29 PM |
| Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 04:02 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
