#15 | |
TRACKBREAD
I can’t remember if my ebrake was pulled when trying to activate it. My traction control button behaving different is suggesting there is another difference. Maybe it’s the cluster? Does the switch wire go directly into the ABS module or does it do through something else? My car is a 13 BRZ, virtually stock. What’s the year of yours? Any other relevant electrical mods besides the cluster? |
#16 | |
TRACKBREAD
Interesting. Maybe it’s a delay in the cluster showing the light? Can you try short pressing the button and see if it comes on after a few secs? |
#17 |
TRACKBREAD
After some careful evaluation in a wet empty private parking lot I’ve come to believe this mod does not change the VSC Logic to the 2017 track mode. The limits feel the same as before. The logic change must be in another module.
#18 | |
TRACKBREAD
2017 abs module on 16 down
The part number on top of the module is 27536ca040. How much coding was involved with the cluster? That might affect things too. Seller on eBay said it’s from a 2017 MT. It must be from a 2017+ because otherwise the repin would have caused the wheel sensor and VSC button to not work. Last edited by Yoshoobaroo; 11-14-2019 at 07:57 PM. |
#19 |
TRACKBREAD
#20 |
TRACKBREAD
That switch kit is clever, I like it! Is the oil temp gauge functional?
My 2013 unit is 27536CA002, the new unit is 27536CA040. Looking at used units on eBay, that puts it in the 2017 range. 2015-2016 units appear to be in the 27536CA020 range, and I found a 2019 that was 27536CA060 For some reason Subaru parts catalogs don’t find these part numbers. Last edited by Yoshoobaroo; 11-15-2019 at 07:40 AM. |
#21 | |
TRACKBREAD
I might look into doing the cluster then. Any problems with odometer mismatch between the ECU and the cluster? |
#22 | |
TRACKBREAD
Oh it’s only Stored in the cluster? I’m used to cluster swaps being a nightmare on bmws because they have to get coded to each other cause they both record it and then cross reference. |
#23 |
Drives: FR-S Whiteout
bummer..
Intent > Content
cowardice is the mother of cruelty. |
#24 |
TRACKBREAD
I think track mode might have more to do with how much throttle gets cut vs how much brake modulating gets done. The VSC module can’t decide how much power to cut. It can only report wheel slip over CAN. Throttle modulation is probably done by the ecu somehow.
I’m still puzzled over the difference in VSC sport button behaviors. I can’t get hill start to work either. Both our cars are 2013 limited, both with 2017/2018 abs modules, only difference is the cluster. I’ll do the cluster swap to see if that changes the button behavior and the hill start. I’ve always wanted oil temp on the dash anyway. @solidsnake11, do you still have the 2013 traction control buttons? |
#25 | |
TRACKBREAD
Okay so it’s not the buttons. You already said you only have the ABS module and the Cluster, but I wanted to confirm that. I never got any abs codes in the first place, probably because i repinned the connector before connecting the module the first time. I tried activating hill start again but my guess is that the cluster actually plays a bigger part than just showing the light. Maybe there are certain CAN signals missing or not passed on when you use the old cluster. I’ll come back with an update after sourcing a 2017 cluster. |
#26 |
Drives: Toyota 86 Turbo, Lexus NX300H
thank you @solidsnake11 .
I installed 2018 BRZ TS abs module(27536CA050) to my 2012 toyota 86 6MT. AND trac mode & hill assist are available now =) I don't have new cluster or new trac button. I only installed 2017 ABS module.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
#27 |
Drives: Toyota 86
Hi,
I've installed a 2017 ABS module from 27536CA030 to 13MY Toyota 86. Now the VSC sport switch should be pressed over 1 second to lit the VSC sport indicator of the cluster. Wow! Thanks.
#28 | |
That's good and all, but did it effect the way intervenes on wheel slip? Is it functionally the same as the track mode on the 2017+? Or did we just change slightly the way it VDC sport gets turned on but nothing else?
Intent > Content
| CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT | DTrouble | CANADA | 0 | 07-19-2017 08:42 PM |
| 2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? | Extreme Dimensions | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 06-08-2017 08:59 AM |
| Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift | ModinJapan | Southern California | 1 | 01-25-2017 12:46 AM |
| WTB BRZ Always On Module | Jordan Silveira | Want-To-Buy Requests | 3 | 08-08-2016 01:30 AM |
| WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module | Danklvr | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-04-2014 05:57 PM |
