#113 |
Little Member
Drives: Bloo - The 13' BRZ
The one made of painters tape, cardboard, and scrap aluminum?
| The Following 3 Users Say Thank You to yelsew For This Useful Post: |
#114 |
#115 |
Drives: Crapcan
#116 | |
Only users lose drugs.
Drives: All the time
Who cares. Worst backyard mechanic ever.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | Ultramaroon (11-15-2019) |
#117 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following User Says Thank You to weederr33 For This Useful Post: | soundman98 (11-16-2019) |
#118 |
Drives: Crapcan
#119 |
Wes
I've noticed my right rear brakes squeak whenever it's raining/snowing and/or cold. I first thought maybe it's the pad wear indicator that started squeaking (is there one on this car?) but the car is only at 50K km (~35K miles) and I feel like the pads should last longer than that. I looked at the rotor and there is a single deep groove that's not present on the other 3 rotors. What could this be? Is it a stone lodged in there?
Instagram: @gt86ws
#120 | |
#121 |
Same! I saw a Mugen version and fell in love.
| The Following User Says Thank You to weederr33 For This Useful Post: | NoHaveMSG (11-14-2019) |
#122 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
| The Following 3 Users Say Thank You to HKz For This Useful Post: |
#123 | |
Senior gif poster
Drives: 2013 Asphalt FRS
That is normal, unless your doing very hard consistent braking your pads are fine. A small amount of rust appears when there is a lot of moisture in the air which can cause a bit of squeaking. You will see once the air dries out and you drive a bit the squeaking will go away. My OEM brake lasted until 80k FYI and over the years it always squeaked a bit after it rains. Also the oem brakes do have a metal bit that is designed to squeal when the pad wears enough. As for the groove, that is concerning, I would off the pads and inspect it. I'm going to guess the guide pin on the caliper could be gunked up causing abnormal wear on that disc. You can remove the guide pin, clean it up, and add some silicone based grease and re insert it. I think Chris FIx has a great how to video detailing the process. |
| The Following 2 Users Say Thank You to DandoX For This Useful Post: | humfrz (11-14-2019), StraightOuttaCanadaEh (11-14-2019) |
#124 |
Senior gif poster
That is some serious braking, sounds like you cooked your brakes which would cause it to overheat and wear out right away. For normal DD the oem brakes last a super long time if there is no auto X or track days. Really the oem brakes don't really do well with auto X or track days that have prolonged hard braking. For normal DD driving, I brake super hard all the time with no engine braking and mine lasted about 80k. Granted I'm in an area where it isn't as hot and I haven't done auto X or track days. |
#125 |
Wes
For the first 40K or so it was mostly highway, and even when I'm not on the highway, I basically don't brake lol. I use engine braking a lot and I anticipate the flow of traffic and let off the gas strategically so by the time the light turns green, the traffic starts moving and I just set off again without having to touch the brakes
Instagram: @gt86ws
#126 | |
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | DandoX (11-14-2019), soundman98 (11-16-2019) |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 01:29 PM |
| Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 04:02 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
