Old 11-02-2019, 08:33 PM   #127
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Code Monkey View Post
Got a JDL ultra quiet front pipe installed. The fitment is great. I will dyno the car again to see how much restriction the OEM front pipe was.
Did you get a chance to dyno the new front pipe?
Old 11-02-2019, 09:02 PM   #128
Chuckable
Drives: 2017 Toyota 86
Ouch. Any signs of it going bad before the trouble shifting gears?
Chuckable is offline   Reply With Quote
Old 11-02-2019, 10:35 PM   #129
Code Monkey
Drives: Subaru BRZ
Not yet. But I had to pull the FP to remove the transmission and the cat is already loose.
When I got the new engine 3k miles ago, I asked the shop to install an aftermarket clutch and a new TOB. There was always a bit of a whine from the transmission on deceleration when engine braking, but I attributed it to the new clutch (dual friction compound). But who knows. Maybe the TOB was not installed properly or was a used one. Aside from that drivetrain whine, there were absolutely no signs, I ran four sessions that day, came to the paddock, and whoa, what's this? @Opie was there and was kind enough to look at my problem and thought it could be a bent shift fork, but the shift fork appears to be fine.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
dowroa (11-02-2019)
Old 11-02-2019, 10:52 PM   #130
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Does the BRZ transmission have an oversized bearing replacement kit? Something where a better overall mechanism is used? I think the snout it replaceable on the BRZ, but the quality of Subaru's throw-out bearings has always been in question for all the Subarus I have ever owned.
dowroa is offline   Reply With Quote
Old 11-02-2019, 11:02 PM   #131
Chuckable
What a bummer, especially considering all the time, effort, and money you have put into the car. Hopefully it is as simple as a bad TOB and nothing else was damaged.
Old 11-02-2019, 11:22 PM   #132
Code Monkey
Drives: Subaru BRZ
I hope it is just the TOB. One of the side clips is missing and I do not think there is anything else in that area that the bearings could come from.
Not really worried about the whole situation, that's the nature of the game I play.
Old 11-03-2019, 11:52 AM   #133
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
So since those ball bearings were in the M/T fluid, they are from inside the transmission assembly. There are several ball bearings in the transmission that are used as detents to align different components. They should never be just floating around in the fluid. Problem seems to be more than just the TOB
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Code Monkey (11-03-2019)
Old 11-03-2019, 01:47 PM   #134
Code Monkey
Drives: Subaru BRZ
Thanks, figured it may be the case! The TOB bearings are bigger too. The clutch looks ok I guess?
Old 11-05-2019, 07:39 PM   #135
Code Monkey
Drives: Subaru BRZ
Sourced a used transmission locally, from a totaled Series.Yellow.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
kch (11-05-2019), Opie (11-05-2019)
Old 11-05-2019, 09:18 PM   #136
Opie
Opie's Avatar
How many miles on your car?
Old 11-05-2019, 09:24 PM   #137
Code Monkey
Drives: Subaru BRZ
Old 11-05-2019, 09:59 PM   #138
Code Monkey
Drives: Subaru BRZ
Just got my oil analysis from Blackstone.
Old 11-16-2019, 06:48 PM   #139
Code Monkey
Drives: Subaru BRZ
Took the clutch to Clutch Specialty and they told me it was ok to run it so it is back in the car.
Got the Verus clutch fork with a new TOB and a clutch fork pivot but then a brand new Money Shift Racing hydraulic TOB came up for sale and I could not pass the deal.
The transmission is back in the car, still need to reconnect all the wiring and finish up hooking up the hydraulic TOB.
MCTeeJ (11-18-2019)
Old 11-16-2019, 08:47 PM   #140
BlueLine
Drives: 2013 Rally Blue w/Bronze wheels MT
I’m jealous of you getting that MSR, I wanted to see if it would have fit my project. I also ordered some stuff from neatgearboxes down in Australia.
About how think do you think that back plate is that gets put into the transmission?
BlueLine is offline   Reply With Quote
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 05:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 09:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 07:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 06:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 11:53 PM
