| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 frs red
I would flash stock tune and have it transported. I've never heard of running a supercharger with a stock flash. Maybe someone else can chime in here?
#16 |
Drives: 2013 Subaru BRZ
what if i drove to dealership with my labtop. flashed it to stock there. have them re-program it. then i can flash it back to my tune. i think that may work.
i mean how bad could the car drive using the default with a supercharger anyways? it would still be drivable at least right? |
#17 | |
#18 |
ProCrastinationConsultant
right until the car starts throwing misfire codes while they pull it into the service bay, and the tech attempts to go ahead and fix those codes...
just be honest with them about it, let them know what you're doing, and how the car will not be driveable while they program the key.
#19 |
no, i dont have larger injectors. i have an automatic. supercharger, flex fuel kit.
custom exhaust system. thats it. i think it may even be drivable on lower RPMs. im not really sure. the tune came from Moto East. But that was three years ago. Should i email and find out? Are they in business still, does anyone know? |
#20 | |
i know right, i need to make sure i communicate it clearly to them to not move the vehicle once the tune is back to default.
#21 |
Contact xero limits. That's motoeasts new name. They'll be able to help you.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | chaoskaze (10-28-2019) |
#22 |
Drives: 2017 BRZ
Unless you can get it at zero boost... It'll run lean. Probably. Check with your tuner maybe.
#23 |
#24 |
#25 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
#26 | |
I talked to Mike over at Moto-East (now Xero-Limit) because he was the one who did my tuning. He couldn't give me any explanation why the dealership can't communicate with the ECU. Nobody can. But he said what I need to do is just replace my 3 bar MAP sensor with my stock sensor, then re-flash the tune to stock, and do this at the dealership so they can gingerly drive it to the service bay, do the work. then i can put back in my 3 bar map sensor, then re-flash it back to my tune. Crazy right? Absolutely nuts I need to do all that just for them to fix my check engine light and also re-program my key-fob. |
#27 |
Back to really simple. Had a friend that my "good" reader would not work, but the cheep one would. It seems that the connecter in the car is not great. I used an extender cord with the good reader and all worked well.
Just a thought. |
#28 |
Drives: 2013 FR-S Series 10
That does sound like quite a mess. I'd try an indie locksmith, i had one copy my current key to an aftermarket key (obviously doesnt help your AC issues)
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| Tags |
| brz, ecu |
| Tuners like "Mugen" or "Spoon" for Subaru? | Seiryuu | BRZ First-Gen (2012+) — General Topics | 21 | 09-08-2018 04:33 PM |
| dealership thats willing to fix timing cover leak for "heavily modified" brz | iarefluffy | Southern California | 14 | 12-29-2017 12:53 AM |
| Will the dealership "ECU Flash" be reset to factory after disconnecting battery? | spatcha88 | Engine, Exhaust, Transmission | 5 | 04-02-2015 03:35 AM |
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... | mav1178 | Other Vehicles & General Automotive Discussions | 42 | 07-07-2014 04:52 PM |
