Old 09-30-2019, 04:09 PM   #15
g e
46k in 2013 and no oil consumption. Always at the full mark.
g e is offline   Reply With Quote
Old 10-01-2019, 10:14 AM   #16
qqzj
Drives: MDX, Camry
Same here. 2013 with 47k. Doesn't burn oil at all.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 10-01-2019, 10:15 AM   #17
qqzj
Drives: MDX, Camry
Old 10-01-2019, 10:49 AM   #18
funwheeldrive
My car doesn't but oil, but getting an accurate reading from the dipstick is a PITA compared to my other cars.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Opie (10-25-2019)
Old 10-01-2019, 12:04 PM   #19
I find it no different than any other car I have ever had. I have always scored the dipstick horizontally with a piece of sandpaper though so maybe all my other cars sucked and I just didn't know.
funwheeldrive (10-01-2019)
Old 10-01-2019, 03:16 PM   #20
funwheeldrive
I've heard of people doing this, maybe I will try it out.
Old 10-01-2019, 03:35 PM   #21
It really works well.
Old 10-23-2019, 10:41 PM   #22
mrntd
Drives: 2017 Series.yellow BRZ
My MINI used half a quart after driving the twisties for half a day. My BRZ has used none at all.
mrntd is offline   Reply With Quote
Old 10-23-2019, 11:46 PM   #23
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
50k miles & no oil consumption & I'm not nice to it....
CB750F is offline   Reply With Quote
Old 10-24-2019, 11:49 AM   #24
Tristor
Tristor's Avatar
I don't have any oil consumption after 30k on the odo, and I track it regularly and otherwise beat the piss out of it.
Tristor is offline   Reply With Quote
Old 10-25-2019, 04:30 AM   #25
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
Zero oil consumption issues with FA20s.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 10-26-2019, 05:40 PM   #26
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I always overfill my car by half a quart since i got oil cooler.......O.o......
So it's always quite a bit higher then the 2nd dot...
I think it's causing a bit of oil leak from having too much oil thou? @Tcoat
Old 10-26-2019, 05:46 PM   #27
Grady
Grady's Avatar
I think that is causing a bit of oil leak from having too much oil thou.
Adding a cooler does not change where the full mark should be. Unless somehow you cooler is mounted high and drains back into the sump.
The Following User Says Thank You to Grady For This Useful Post:
norcalpb (10-26-2019)
Old 10-26-2019, 06:19 PM   #28
norcalpb
norcalpb's Avatar
You should always check your oil when hot. When your oil is hot the thermostat will be open on your sandwich plate which means everything is filled with oil.
Just hit 1000 Miles vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-16-2014 06:48 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 01:31 PM
1000+ miles jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 02-02-2013 01:23 AM
Coming up on 1000 miles... jm1681 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-30-2012 03:09 PM
1000 miles jarviz Scion FR-S / Toyota 86 GT86 General Forum 8 06-29-2012 03:42 PM
