Drives: Rocket Bunny FR-S
Manual grinding sound
Hey guys,
Im new to manual cars and I recently just learned to drive. Im not great at it and i still occasionally stall but something that has bothered me Was that when i slow down for a stop Light i put it in neutral, then as i am still moving at say 15 mph with the clutch still in after putting neutral, i move it to First with the clutch still down to get read for a green light at a stop, when doing this i hear a grinding Sound right before it fully enters 1st gear and i feel it in the stick everytime maybe even other gears. Anyone know if this is normal? |
#2 |
are you pushing the clutch pedal all the way down? are you jiggling the shifter while your in neutral?
#3 |
Señor Member
Drives: 2013 SSM DZE BRZ
Stop putting the car in first gear at 15 MPH. You're going to destroy your synchros. Only engage first when stopped or barely moving.
#4 |
My friend said i may not be pressing ALL the way down
Im not downshifting to first though, im in neutral while the clutch is sill down breaking for a stop light and right before while the clutch is still in, i move it To first to prepare to go from a stop when the light turns green |
#5 | |
Señor Member
#6 | |
Drives: NB Miata
#7 |
Señor Member
| The Following User Says Thank You to Subie For This Useful Post: | MiguelAE86 (07-19-2012) |
#8 |
Drives: Black GTS
Yeah i agree, dont get into 1st unless your not moving.
#9 |
1st gear should ONLY be used at a complete stop. DO NOT ever down shift in to first...fastest way to screw shit up
#10 |
Drives: NB Miata
#11 |
Señor Member
No; you'd have to rev-match perfectly while in neutral to downshift (i.e. push the gearstick out of gear without using the clutch, rev-match, push the gearstick into the next gear), and time upshifts perfectly so that the input shaft speed would slow down to the right speed to match the output shaft as you engage the the next gear. It requires a lot of precision. I've personally never tried clutchless shifting.
#12 | |
#14 |
Enthusiast
Drives: Crystal Black BRZ Limited
Use your brakes when you get under 15.. Those are way cheaper to replace..
Instagram: Neekowahhhh
Mishimoto Air Induction Hose;K&N High Flow Air Filter;Berk Tech Catless Front Pipe;Invidia N1 Catback Exhaust TT;Matte Bronze XXR 527 17x8.25 ET 25 |
| notchy/gritty transmission. every gear grinding | prest1ge | Engine, Exhaust, Transmission | 41 | 12-09-2012 06:45 PM |
| Sound tube mod? | smbrm | Engine, Exhaust, Transmission | 25 | 06-20-2012 07:24 PM |
| SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) — General Topics | 15 | 06-14-2012 11:33 AM |
| Southeast sound OFF! | OldSkoolToys | Southeast | 133 | 05-25-2012 12:31 AM |
| What should the FR-S sound like? | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 07-31-2011 01:33 AM |
