Old 08-26-2019, 09:39 AM   #15
MichaelBrown86
MichaelBrown86's Avatar
Drives: 2015 Subaru BRZ Limited
Well, I don't think my wife is happy with me... Haha!
I went and got a TRD catback exhaust to match my TRD intake.
It's a bit louder with the Tomei UEL Headers + Overpipe. I still have the stock front pipe, so I'm sure it could be louder, but overall, the sound is great. I can really hear the boxer-growl now.
Build Thread:
https://www.ft86club.com/forums/showthread.php?t=133150
MichaelBrown86 is offline   Reply With Quote
Old 08-26-2019, 09:40 AM   #16
MichaelBrown86
A bit of an update: I decided to focus on some small/misc. pieces before purchasing anything big (Turbo, Supercharger, etc). Just some little things that would improve the overall feel of the car.
Transmission and Differential fluid change w/ Motul Gear 300 75W90 Synthetic Fluid
White Line steering rack bushings
White Line rear diff. carrier bushing inserts
White Line rear subframe bushing inserts
White Line transmission bushing insert
TorqueSolutions short shifter
Perrin shifter bushing
3DMAXpider front floormats
Black spline-type lug nuts + studs
Build Thread:
Old 08-26-2019, 10:56 AM   #17
ArchReactor86
Drives: 2013 GBS BRZ Limited
Does the Perrin shifter bushing fix the shifting issues? I have a 2013 and 2nd gear is super hard to use. Was wondering if it did anything.
ArchReactor86 is offline   Reply With Quote
Old 08-29-2019, 04:51 PM   #18
MichaelBrown86
I never really had an issue with shifting to be honest, but the bushing did tighten shifts up quite a bit.
Also, Update: I decided that I hated the TorqueSolutions short shifter (seriously bad quality)
So I'm returning it and swapping it out with the IRP V3 Short Shifter, (I'll also return the Perrin bushing because the IRP kit removes the carrier which utilizes it) but the Perrin bushing was nice.
(PM me for further questions please)
Update: Oh man! I'm so glad I got this IRP Shifter! Absolutely Amazing! I highly recommend this to anyone. Yes, the price is a bit steep, and the install is a little more involved than your standard short shifter, but totally worth it!
Build Thread:
Old 09-03-2019, 09:30 AM   #19
MichaelBrown86
So, as stated in the beginning, my BRZ is my daily-driver.
That being said, it has to be comfortable enough for my commute to work, and my wife has to approve when we go out for date-night.
After the TRD cat-back, she wasn't very happy. Lots of drone, and it was a little loud. So I decided to try and remedy the situation by adding a second resonator to the front pipe.
As luck would have it, the self-serve shop that I go to had an extra OEM front-pipe lying around after someone installed an aftermarket one. They know me pretty well there, so they let me cut out the resonator (leaving the cat, that they actually wanted).
After finding a suitable spot for the resonator that wouldn't interfere with the chassis or any moving parts, we cut/welded it in.
Thoughts: The volume didn't decrease that much, as resonators are more focused on cancelling out noises, instead of reducing volume. But oh man! The drone is gone!
I'm still gonna keep an eye out for other solutions that might reduce the volume just a little bit more, but for now, i'm very happy.
Build Thread:
Old 10-17-2019, 12:29 PM   #20
MichaelBrown86
Just a few more comfort mods.
First, I added the armrest offered on the JDM vehicles. It feels really nice to be able to just rest my arm on long drives or sitting at traffic lights.
Second, I placed a bit of sound deadening around the underside to reduce noise from the drive train (Does a pretty good job).
Ofcourse, I'm not quite finished with my sound deadening, I still have the front half to complete whenever I get time. Highly recommend it. Worth every ounce.
Build Thread:
Old 10-17-2019, 12:53 PM   #21
DaSilva3525
Drives: 2013 Brz
Nice build so far, thought out and clean! I will never understand giving into a woman over personal items that "said" man works hard for / really enjoys but hey each their own.
Most people make it louder so they don't even want to get in it lol.
DaSilva3525 is offline   Reply With Quote
The Following User Says Thank You to DaSilva3525 For This Useful Post:
MichaelBrown86 (11-25-2019)
Old 10-17-2019, 02:11 PM   #22
MasterBandit
Drives: Scion 2015 FR-S
Very nice build. I am in the same boat as you. Just got my new-to-me 2015 FR-S 57k miles.
Can you post current pictures of your BRZ?
Also, have you done anything else cosmetic besides the lights?
MasterBandit is offline   Reply With Quote
The Following User Says Thank You to MasterBandit For This Useful Post:
Old 10-17-2019, 02:12 PM   #23
MasterBandit
This might help
https://www.urbandictionary.com/defi...?term=Mandilon
Old 11-25-2019, 09:55 AM   #24
MichaelBrown86
I figured i'd add an update to what I've done to my BRZ over the past few weekends.
First up was a budget brake upgrade from Rock Auto: FHI WRX 4-piston fixed calipers ($140/caliper) + F&R StopTech stainless steel brake lines.
(side-note 1: If you have Enkei RPF1's 17x9 +45, you will need a 5mm space to clear the calipers)
(side-note 2: The FHI WRX brakes are a nice caliper upgrade because of their obviously low cost compared to the Brembo's, and you also lose approximately 2lbs per caliper compared to stock)
(side-note 3: Part #'s for each caliper are: NUGEON 9701335B & NUGEON 9701335A. No brackets needed for install. They are 2006-2007 Impreza brakes.)
And finally, I installed the OEM cat-back exhaust and sold the TRD cat-back. It was just a little too loud for me; the volume, the drone, etc. Maybe i'm just getting older?
I also have a request; I want most of this thread to be filled with helpful info and updates, not random comments/questions. If you have questions, please just PM me. I'll gladly answer any of your questions. I was just hoping to keep this thread as more of a journal than a chat. Thank you.
Build Thread:
Old 02-17-2020, 01:13 PM   #25
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
So is the IRP scca solo STX legal?
SON1C is offline   Reply With Quote
Old 02-19-2020, 01:41 PM   #26
MichaelBrown86
I've looked over the 2019 SOLO Rules and under Chapter 14, section 10, Line G, it states:
"Any mechanical shift linkage may be used."
Sounds good to me.
Build Thread:
Old 02-19-2020, 04:31 PM   #27
ka-titties
Drives: 2013 BRZ Limited 6MT
Next up was to fix a leaking valve-stem on one of my RPF1's. I would lose 10 PSI over night, and had to keep pumping it up every morning until I finally fixed it over the weekend.
What year/model do you search for on RockAuto for the brakes? Any bracket needed to install?
ka-titties is offline   Reply With Quote
Old 03-16-2020, 10:40 AM   #28
MichaelBrown86
A small update:
I've swapped out the OEM Trans Mount + Whiteline Insert setup for a Megan Racing Trans Mount.
I felt like the shifts could feel ever so slightly more positive with a mount that didn't have a cavity (even if filled with an insert). My suspicions were correct, even though the the new mount introduced an ever so slight increase to NVH during cold mornings, it quiets back down after a few minutes of driving.
I also replaced the rear tag-lights and fog lights with LED's. Nothing crazy, but i'm now able to say "All exterior lights are either LED or HID". Now, I guess I have to work on interior lights.
Build Thread:
Michael's 2014 Whiteout Scion FRS Build Michael Member's Car Journals 35 04-29-2020 12:09 PM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Michael's WTB Thread Michael Want-To-Buy Requests 48 02-03-2020 09:13 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
