Old 09-14-2019, 08:01 PM   #1
qqzj
Drives: MDX, Camry
Update non-performance BRZ to PP
After I install the PP Brembo calipers/rotors/pads/wheels and Sacks dampers, what else are left? Please ignore appearance pieces.
Also for the brake system, is there anything else to change? Master cylinders? Proportioning valves? Do they use the same caliper brackets/carriers?
qqzj is offline   Reply With Quote
Old 09-14-2019, 08:58 PM   #2
Windycitystig
Drives:
Wider wheels, different rear sway bars, rear spring rate.
Windycitystig is offline   Reply With Quote
Old 09-28-2019, 08:47 PM   #3
Ernest72
Does really drive any better after all that?
Old 09-28-2019, 09:57 PM   #4
qqzj
Drives: MDX, Camry
I don't know. I only replaced the wheels to PP wheels. It drives better now because of new tires. I am curious how big of a difference the damper and brakes make for street driving.
Sent from my Pixel 3 XL using Tapatalk
Old 09-28-2019, 10:13 PM   #5
86MLR
86MLR's Avatar
Nope
PP came standard on my 2017 Limited Edition 86
The Brembo's are good if you're really using your brakes, are they required on a streer car, nope, they do look nice though.
The Sachs coilovers, well, I thought they were rubbish on anything that wasn't as smooth as a pool table, I believe the valving was the issue.
My Sachs dampers and springs lasted about 3k km. I sold them for $250.
I replaced them with MCA street performance for a vast improvement everywhere.
https://mcasuspension.com/suspension
I have also installed the MCA traction mod on recommendation
https://mcasuspension.com/traction-mod
IMO effort would be better spent on good aftermarket stuff and camber solutions.
Opinions may vary
The Following User Says Thank You to 86MLR For This Useful Post:
soundman98 (09-29-2019)
Treadstone Performance Turbo Kit Update! kmbkk Forced Induction 277 01-17-2020 12:15 AM
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 10:23 PM
Excelerate Performance: Your Northeast Performance and Installation Center ExcelerateRep NY / NJ / CT / PA 40 07-22-2014 06:55 PM
