| Engine Swaps Discussion of engine swaps. |
#15 | |
Drives: Q5 + BRZ + M796
The point about the adaptive suspension, active diff, stiffer chassis, etc is that the Supra has better components which is why it is heavier and is why it has more value. Again, by the time someone completes the swap, they may end up wishing their Supra clone was just an actual Supra, especially after spending Supra money and having less quality parts. Like I said below, I agree with you that a racecar is the most logical application for this setup. Also, it could be cheaper trying to make the 86 more powerful with this swap than trying to make the Supra lighter. It would be hard to remove sound deadening; it would be hard to remove and sell the adaptive suspension system in order to install static compression; it would be hard to remove thickness from the subframe or suspension components to match that of the 86; it would be harder to remove quality from the interior without a full strip; it would take more effort to swap to a smaller brake setup to match the 86. I agree that this swap is most logical/cost-reasonable as a racecar likely using a used, higher mileage 86 along with a basic ECU package just to get the car running.
#16 | |
On the manual transmission, like I said earlier, that is one of the best advantages here. The engine and transmission could be bought as one assembly. With the 2JZ, the CD009 and adapter kit is another large expense. With the Pure Auto K24 swap, there is a need to source a S2000 tranny and an adapter kit. Usually an engine and transmission joined together are cheaper and less headache.
#17 | |
Drives: 16' BRZ
#18 |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#19 |
Drives: '13 FRS - STX
Shit, 400whp with a tune and exhaust on pump fuel is plenty for this car and cake for a B58 to make.
And if you can cross your i's and dot your t's you can even keep it street legal in California. |
| The Following User Says Thank You to strat61caster For This Useful Post: | yelsew (09-26-2019) |
#20 |
Drives: UK GT86
After a quick search I can't find much info on ECUs but I don't think that the M150 can run the DIs that the B58 uses. I suspect that the N55 uses similar injectors and seems that the M142 is used, but then I'm not sure you can get the factory accessory compatibility that you get with the M150.
.: Stealth 86 :.
#21 |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#22 |
Drives: 16' BRZ
#23 |
#25 |
Why no xDrive while you're at it? Go all out.
#26 |
bump
#27 |
#28 | ||
An LS swap with full can integration will cost more than just buying a C5 Z06... Quote:
The FA20 also has twice as many heads and cams. These boxers are VERY heavy for all aluminum 4 cylinders. According to published weights I can find, the FA20 engine and transmission is 480lbs. The B58 is 306lbs and the ZF 8HP is 192lbs (498lbs combined). Not lighter than the FA20 driveline, but also a completely negligible weight gain for the performance difference.
