Old 09-24-2019, 01:14 AM   #1
d0aner
Drives: 2017 86 GTS
Nur Spec Side Skirt installation template?
Does anyone have a template on where to drill in the side panel for this side skirt installation?
Thanks in advance
d0aner is offline   Reply With Quote
Old 09-24-2019, 02:51 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@d0aner, Nur spec/aero kit parts are hard to come by within the forums, especially the templates. Your best bet is either have a body shop do it or put some marks (I.E. toothpaste) where the clips slide in on the side skirt and imprint it onto the side of the vehicle. These parts are usually factory installed if I recall due to it having to be drilled into the side of the car.
Bach415 is offline   Reply With Quote
Old 09-24-2019, 08:48 PM   #3
d0aner
Drives: 2017 86 GTS
@Bach415 - thank you, probably will head to a body shop now. Initially thought the TRD and Nur spec side skirts were the same thing, wished I knew that before purchasing them haha
Old 09-25-2019, 02:26 AM   #4
Bach415
Bach415's Avatar
Np. TRD and Nur Spec/Aero kit are completely different. Nur spec has one mounting point in the front with the rest of the mounting points drilled into the side of the car w/o weather stripping. TRD has 2 mounting points in the front and 2 in the rear without the need of drilling and using weather stripping + adhesive to hold onto the side. I personally have the nur spec side skirts that are being repaired (slowly). I am converting it to work like the TRD ones w/o drilling.
Old 09-25-2019, 02:48 AM   #5
spike021
spike021's Avatar
TRD ones do have five holes on the bottom. They clip into the bottom of the rocker panel. Unless you mean drilling elsewhere.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 09-25-2019, 12:03 PM   #6
Bach415
Bach415's Avatar
Both the trd and nur spec has the 5 holes at the bottom of the rocker panel. Nur spec actually requires you to drill into the panel right under the door as there will be clips that hold the side skirt into the body. It’s like the wrx sti side skirts mount but without the holes actually being premade
WTB (NORCAL): overpipe OP, genuine STI side skirt (right side) BabaYaga Want-To-Buy Requests 2 07-06-2017 03:32 PM
side skirt installation causing rust? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 06-06-2016 04:03 PM
WTB: Vertex Side skirt or Origin lab skirt Vesalera Want-To-Buy Requests 0 03-16-2015 09:00 PM
Help needed with FR-S CS side skirt installation! Stormtrooper FRS Cosmetic Modification (Interior/Exterior/Lighting) 5 04-21-2014 03:54 PM
