#15 | |
Drives: Crapcan
#16 |
Weight Weenie
Drives: 15 FR-S
#17 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Dampening is when you're getting something wet
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| The Following User Says Thank You to Goingnowherefast For This Useful Post: | whataboutbob (12-24-2019) |
#18 | |
Only happy when it rains.
Drives: series.blue
#19 |
Drives: 2018 Subaru BRZ Limited with PP
So if it is the driveshaft, then it certainly sounds like an imbalance. I don't know where you can take it to get it balanced, but that would certainly solve your problem if it IS in fact the driveshaft and you would like to hold on to it.
Some interesting instructions to finding if you have an imbalanced driveshaft I found here. I would be far too lazy to do this though I guess in your situation it's basically impossible anyway, as you only experience it at higher RPM's.http://www.demandaam.com/technical-s...haft-balancing |
#20 |
Drives: 2013 BRZ Sport-Tech
Since it's always around 5500 RPM in any gear, wouldn't it make sense for it to be something on the engine side of the transmission rather than the driveshaft?
#21 | ||
Drives: Crapcan
![]() Quote:
I have read in other threads that balancing didn't help. |
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Goingnowherefast (09-20-2019) |
#22 | |
#23 |
Drives: 2015 FRS
SPL's kit has shims, so you can install at OE height, or raise/lower it depending on what you want to do. Super easy to adjust.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
#24 |
Drives: 2015 FRS
How many out there with CF driveshafts have vibrations ?
'15 FRS - GLTC spec
#26 | |
Drives: 2015 FRS
I'm beginning to think if you have stiffer motor, trans, and diff mounts, typical of a race car, then virtually any 1 piece drive-shaft will vibrate badly. Maybe I'm wrong.
'15 FRS - GLTC spec
| The Following User Says Thank You to prandelia For This Useful Post: | Dzmitry (09-25-2019) |
#27 |
Wes
How bad are these vibrations? I have vibrations and/or resonance from either one, or a combination of, subframe and diff bushings, shifter bushing and trans insert and I really don't mind them. It makes the car sound raw and visceral. So how would a carbon driveshaft worsen the vibrations? Any insight on this? I wonder if anyone's done it in the same order
Instagram: @gt86ws
#28 |
What you said there is probably very true. As the motor and trans have natural vibrations, having mounts on them sends it to the rest of the chassis and parts. In this case, your driveshaft would certainly gain some substantial vibration, and not due to an imbalance (which makes more sense, not sure why I didn't think of that before).
| Hood Vibration Question | shinbatsu | BRZ First-Gen (2012+) — General Topics | 10 | 07-02-2023 07:06 AM |
| ATI Harmonic Dampner | JJD28 | Engine, Exhaust, Transmission | 19 | 07-03-2017 05:14 AM |
| Question weird vibration/camber | dillanp86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 05-12-2017 11:43 PM |
| Harmonic Noise from rear Differential at 69 MPH solved | Avion | Engine, Exhaust, Transmission | 0 | 01-28-2016 08:51 PM |
| New owner! Question about warranty and brake pedal vibration | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 12-10-2014 12:22 PM |
