Old 09-15-2019, 10:01 PM   #71
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by GrantedTaken View Post
LOL, have you ever tried Googling parts quality ?
It's like Googling about what oil to use.
@Tristor knows his stuff, so I will ask him directly.
Yes, yes I have. It's not very hard -____-
MS, CSCS, TSAC-F, CPT
Old 09-15-2019, 11:12 PM   #72
GrantedTaken
https://www.autoserviceprofessional....disc-brake-pad
GrantedTaken is offline   Reply With Quote
Old 09-15-2019, 11:57 PM   #73
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Last question.
Is it worth getting Centric PQ Pro?
They have some red abrasive layer?
They are like a few bucks more, so basically the same price.
CENTRIC 50011240 PQ PRO; w/Shims and Hardware Info
Rear; 292mm Front Disc; Vented Rear Disc
$31.89
CENTRIC 50015390 PQ PRO; w/Shims and Hardware Info
Front
$35.79
Why not go with the proven examples that have been suggested?
The Following User Says Thank You to Summerwolf For This Useful Post:
venturaII (09-16-2019)
Old 09-16-2019, 12:13 PM   #74
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Because by picking ANYTHING different from what the rest of the community recommends as a byproduct of experience, he gets to pretend he secretly knows something we don't, when it's really just dumb luck. But hey - lots of people feel the need to think they're the smartest guy in the room. His questions suggest otherwise.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Summerwolf (09-18-2019), wparsons (09-17-2019)
Old 09-16-2019, 01:27 PM   #75
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
1) Go to the first car you see in any parking lot.
2) Look inside the wheels
3) This is what you will see.
Shocking that this is news to some people.
Is the BRZ your first car ?
This is the dumbest way to inspect brake pads. Why? You’re only looking at half of the pads.
Any halfway decent mechanic, DIY or professional, will look at both outside and inside pads during an inspection.
So yes, you’re right. This is a shitty design. Should’ve made the rotors transparent.
Spuds (09-17-2019)
Old 09-16-2019, 01:35 PM   #76
toast
Drives: 14 BSP Edelbrock BRZ
In Star Trek IV they gave us the designs for transparent aluminum but Scotty didn't mention anything about transparent steel. Aluminum brake rotors would suck, so we're SOL.
toast is offline   Reply With Quote
The Following 3 Users Say Thank You to toast For This Useful Post:
Spuds (09-17-2019), Tcoat (09-16-2019), Ultramaroon (09-16-2019)
Old 09-16-2019, 01:35 PM   #77
GrantedTaken
Centric is exactly what he suggested. I'm just pointing out a premium version of the initial recommended centric.
Old 09-16-2019, 01:47 PM   #78
Summerwolf
Panda Trueno
Summerwolf's Avatar
Correct. It's like you want to use any part that hasnt been suggested or numbers supplied for.... just because.
Old 09-16-2019, 02:00 PM   #79
GrantedTaken
No, there may be a reason to avoid the PQ version of the pad. There is a reason he didn't suggest it in the first place, since the prices are similar. Either he's aware of this version, or he's deliberately avoiding them.
Old 09-16-2019, 03:12 PM   #80
venturaII
venturaII's Avatar
....but..but...did you know about the PQ version of the pad? Because he does.
The Following User Says Thank You to venturaII For This Useful Post:
Summerwolf (09-16-2019), wparsons (09-17-2019)
Old 09-17-2019, 10:47 AM   #81
wparsons
wparsons's Avatar
Even worse, only looking at one end of one pad! The wear at the front edge of the pad could be far worse.
And the calipers/brackets too!
flickr
Spuds (09-17-2019)
Old 09-17-2019, 10:53 AM   #82
churchx
churchx's Avatar
Drives: 2014 GT86
No need for transparency. Just add webcam for each caliper and stream 4 videos real-time to audio headunit screen.
The Following 3 Users Say Thank You to churchx For This Useful Post:
Tcoat (09-17-2019), weederr33 (09-17-2019), wparsons (09-17-2019)
Old 09-17-2019, 11:07 PM   #83
mav1178
mav1178's Avatar
nah.
Use the Force.
Old 09-18-2019, 11:26 AM   #84
GrantedTaken
Not really. The pad lays flat.
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 04:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
Vinyl on driver's seat split open; dealer will replace babydriver Cosmetic Modification (Interior/Exterior/Lighting) 2 12-20-2014 09:55 PM
Why do my Stoptech brakes squeel so loudly? Fix or replace? eikond Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-20-2014 03:17 PM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 04:55 PM
