Old 09-08-2019, 12:32 PM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by extrashaky View Post
God, the whining.
I always thought 'whining' was a clue that the pads or the disks are on their last legs.
The Following 3 Users Say Thank You to JD001 For This Useful Post:
soundman98 (09-08-2019), Tcoat (09-08-2019), TunaNoCrust (11-15-2019)
Old 09-08-2019, 01:06 PM   #16
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
No, you're thinking of "squealing"!
Whining is what you hear from your manual transmission if it has straight cut gears or no oil.
Old 09-08-2019, 01:13 PM   #17
GrantedTaken
Plenty of meat left that would be visible on other cars
GrantedTaken is offline   Reply With Quote
Old 09-08-2019, 01:26 PM   #18
OK so were is the caliper?
Old 09-08-2019, 01:29 PM   #19
GrantedTaken
Where is it? I had to lift it up. After I removed the wheel. After I jacked the car.
That is the entire basis of my whining and bitching and ranting!
Old 09-08-2019, 01:30 PM   #20
Hoahao
Drives: 2014 Monogram Hot Lava
Hey give him a break. He missed at least two other brake pad threads to whine in. Not even sure what he is looking at on other cars since about 99.9% of them are the exact same setup as this.
I am much more perturbed that I have to open my hood and pull out a sick to check my oil. What is this 1922?
Thanks Tcoat!! I was wondering if I could complain here about how screwed up the dipstick is. Er, on the car, not the OP!!
It's all about gearing and steering.
Hoahao is offline   Reply With Quote
Old 09-08-2019, 01:33 PM   #21
How would that be visible with any other car with calipers? What cars did you own where that was open and visible?
Old 09-08-2019, 03:22 PM   #22
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, the really annoying thing about this car is that I have to stick the key in it every time I want to drive it. You look in every other car in the parking lot and there is a button to start it! Some you don't even have to start!
The Following User Says Thank You to Spuds For This Useful Post:
spike021 (09-10-2019)
Old 09-08-2019, 04:30 PM   #23
GrantedTaken
Go to any parking lot, and look at the calipers of any car.
You will clearly see the brake pads
Old 09-08-2019, 04:35 PM   #24
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Jesus OP, how hard is life for you?
MS, CSCS, TSAC-F, CPT
weederr33 is online now   Reply With Quote
Old 09-08-2019, 04:44 PM   #25
soundman98
ProCrastinationConsultant
soundman98's Avatar
Every other car I've owned, the pads are in plain view.
what other cars have you owned?
Spuds (09-08-2019)
Old 09-08-2019, 05:01 PM   #26
Dake
Dake's Avatar
Lonely or bored maybe?
Clueless idiot.
Go to any parking lot, moron, and look at the calipers of any car.
Bruh, you really gotta relax.
I can't see the pads on any of the cars in my garage right now. At best, I can potentially look at the bottom of the calipers on my wife's Yaris and deduce the pad thickness by the gap next to the rotor. I might be able to see the FR-S's if I had my thinner-spoked, slightly larger track wheels on, but I doubt it.
That being said once the wheels are off, the "window" in the caliper is fine for a quick check when I rotate tires (I'm not sure why you can't see it). If it gets to the point that I can't tell from the window, then it's getting close but here's the thing - the brakes on these (and most modern, small) cars last a crazy long time. I still have the original pads on my '13 with 50k miles, and that includes an average of six AutoX a year since new (I do swap out for track pads on track days). My wife's Yaris has 100k+ miles on the original pads, and there's still a ton of life left in them! I bought a new set just b/c I figured it was probably time, and the original pads are still well over half the thickness of the new ones!
That being said, as others have mentioned it's very easy to loosen the bottom bolt and remove the top to swing the caliper out if you want to double-check. If you check them when you rotate your tires at an oil change, they will not go bad in the time between one oil change and the next.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
Tristor (09-10-2019)
Old 09-08-2019, 05:15 PM   #27
I think the pads are low, but I can’t even see the pad thickness
I literally had the wheels off, and I have no clue if the pads are low.
There is no where to see the pad. Totally blocked views.
How are you supposed to see if your pads are low?
"I can't even see if my pads are low. Worst brake design ever."
Well, I don't know bout that -
Back in the day, to inspect the brake shoe thickness, one had to first jack up the car with a flimsy bumper jack, then go find the cement blocks (that your dad used for something else) to put under the car, then find the big star lug nut wrench (that your brother used and didn't put back), then take off the wheel.
Next, pull on the brake drum and see that it is stuck, so go find the BFH (that someone didn't put back in the combine's tool box) then beat on the drum to the point you were afraid you were going to break it. Then if you were lucky, the drum would pop off, exposing you to a face full of finely ground asbestos fibers for you to inhale.
NOW, you can inspect the brake shoes for wear.
Oh, did I mention that, just as you started, it was getting dark and starting to snow and the wind was whipping snow around from both sides of the car?
PS - I left out important step, who knows what it was?
The Following 5 Users Say Thank You to humfrz For This Useful Post:
DandoX (09-10-2019), dtbdan (09-09-2019), JesseG (09-08-2019), Spuds (09-08-2019), WolfpackS2k (11-19-2019)
Old 09-08-2019, 05:21 PM   #28
Spuds
The Dictater
Spuds's Avatar
Clueless idiot.
What does that have to do with having to get keys out of my pocket to start the car?
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
