Old 09-07-2019, 10:25 PM   #1
GrantedTaken
I can't even see if my pads are low. Worst brake design ever.
I think the pads are low, but I can’t even see the pad thickness
I literally had the wheels off, and I have no clue if the pads are low.
There is no where to see the pad. Totally blocked views.
How are you supposed to see if your pads are low?
GrantedTaken is offline   Reply With Quote
Old 09-07-2019, 10:45 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
take 1 bolt out of the caliper and rotate the caliper out of the way.
The Following 16 Users Say Thank You to soundman98 For This Useful Post:
alphasaur (09-10-2019), arxm (09-24-2019), DarkSunrise (09-13-2019), e30kawi (12-13-2019), jcw99 (11-16-2019), JoeC (09-07-2019), JohnJuan (09-09-2019), Jyn (09-11-2019), KR-S (09-24-2019), mrderp (09-13-2019), new2subaru (09-07-2019), spike021 (09-10-2019), Tristor (09-10-2019), weederr33 (09-08-2019), WolfpackS2k (11-19-2019), ZionsWrath (09-08-2019)
Old 09-07-2019, 11:31 PM   #3
JoeC
Drives: Subaru BRZ Limited
seriously? remove one bolt and rotate the caliper up. That can't possibly be the "worst brake design ever".
It takes longer to remove the wheel than it does to swap the pads.
JoeC is offline   Reply With Quote
The Following 7 Users Say Thank You to JoeC For This Useful Post:
jcw99 (11-16-2019), mrderp (09-13-2019), Tristor (09-10-2019), TunaNoCrust (11-15-2019), weederr33 (09-08-2019), wparsons (09-13-2019), ZionsWrath (09-08-2019)
Old 09-07-2019, 11:42 PM   #4
soundman98
soundman98's Avatar
i've never had a set of pads that's easy to see without moving the caliper
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Old 09-07-2019, 11:47 PM   #5
Impureclient
Drives: 2015 FR-S
Should have dug up even more dead threads in the brake subforum and see where this goes. Try the Issues/Warranty subforum too. Just get silly.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
weederr33 (09-08-2019), ZionsWrath (09-08-2019)
Old 09-07-2019, 11:47 PM   #6
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
math Mostly
isnt it an interval anyways? check the brake pads every 15k or something? I typically swap em out anyways for what I do and then add that to my list of "check at _____ interval) which literally means take em out and look at how they wear.
only pads that are easy to see are those held in place by a snap clip or a single bolt on racing calipers. you got a factory car with sliding calipers. *shrugs*
Clutch Dog is offline   Reply With Quote
The Following 3 Users Say Thank You to Clutch Dog For This Useful Post:
Old 09-07-2019, 11:54 PM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
OP, you need to start reading the DYI section. There’s a DYI for just about anything to do with this car and it’s growing. Take advantage of those who took the time to create them and learn how to do the job before you even start.
The Following 4 Users Say Thank You to new2subaru For This Useful Post:
jcw99 (11-16-2019), weederr33 (09-08-2019), wparsons (09-13-2019), ZionsWrath (09-08-2019)
Old 09-08-2019, 01:47 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
I agree, I don't like sliding calipers. All exonomy cars should have come with monoblock 4 piston calipers stock.
And that little window on top of the caliper that you can see pad thickness through is stupid too, let's my pads cool off too much when i drive in snow with stock primacy tires.
The Following 7 Users Say Thank You to ZionsWrath For This Useful Post:
Feistyfrog (09-08-2019), Impureclient (09-08-2019), soundman98 (09-08-2019), Spuds (09-08-2019), Takumi788 (09-09-2019), weederr33 (09-08-2019), wparsons (09-13-2019)
Old 09-08-2019, 11:31 AM   #9
GrantedTaken
Wow, I can't believe you actually need to remove calipers just to inspect the pad thickness.
Every other car I've owned, the pads are in plain view.
Most cars, you can see the pad thickness without even removing the wheel.
What a disgrace.
The Following User Says Thank You to GrantedTaken For This Useful Post:
Old 09-08-2019, 11:34 AM   #10
GrantedTaken
That window is useless, particularly on the rear wheels.
And the wheel needs to be removed.
How did they make a car where you can't see the pads with the car on the ground?
Next time you're in a parking lot, look at any other car
You can see the pads without touching a single tool.
Old 09-08-2019, 11:42 AM   #11
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
look at the caliper from above, you can see the pad plain as day.
if you can't see it, it's damn low.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 09-08-2019, 12:10 PM   #12
extrashaky
Drives: 2014 BRZ Limited
God, the whining.
The Following 15 Users Say Thank You to extrashaky For This Useful Post:
arkanist (09-11-2019), DarkPira7e (09-10-2019), dtbdan (09-09-2019), JohnJuan (09-11-2019), meWant (09-12-2019), Mr.ac (09-10-2019), new2subaru (09-08-2019), Qadthane (09-08-2019), soundman98 (09-08-2019), spike021 (09-10-2019), Tcoat (09-08-2019), Tristor (09-10-2019), weederr33 (09-08-2019), wparsons (09-13-2019), Yoshoobaroo (09-08-2019)
Old 09-08-2019, 12:24 PM   #13
GrantedTaken
This may actually be the answer.
I'll go remove the wheel and caliper now.
Old 09-08-2019, 12:28 PM   #14
Originally Posted by extrashaky View Post
God, the whining.
Hey give him a break. He missed at least two other brake pad threads to whine in. Not even sure what he is looking at on other cars since about 99.9% of them are the exact same setup as this.
I am much more perturbed that I have to open my hood and pull out a sick to check my oil. What is this 1922?
dtbdan (09-09-2019), korhun (09-12-2019), weederr33 (09-08-2019), wparsons (09-13-2019)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
