Drives: '13 SWP GT86
10 inch tablet mount?
Does anyone have a good solution how to mount a 10 inch tablet (portrait orientation), and not block the headunit or climate controls etc?
I use one with my Ecutek bluetooth interface to monitor things. Would be nice to have it mounted for easy overview.
IG @squareddesign
http://www.squareddesign.se |
#2 |
Drives: BRZ Limited
You can use either the Arkon arm grip or the Beatsonic dash holder. I've used both and I'll see if I can upload photos later.
#3 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
#4 | |
Drives: BRZ Limited
Beatsonic mounted horizontally ![]() Beatsonic mounted vertically ![]() Arkon arm grip mounted horizonally ![]() Arkon arm grip mounted vertically ![]() For both the Beatsonic and Arkon ones, I switched out the plate for the Scosche magnetic joint so the tablet has the flat magnet in the back. If you want it to be more secure, you can always use the normal grip, but I wanted something that I could more easily mount and dismount, and be cleaner. edit-- As you can see, I also had mounted it on brackets over the climate controls as well. Last edited by nwgabrz; 09-05-2019 at 01:06 PM. Reason: As you can see, I also had mounted it on brackets over the climate controls as well. |
| APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk | Tony.86_ | Exterior Parts (Aero, Lighting, Etc.) | 5 | 01-03-2020 11:03 PM |
| FS: OpenFlash Tablet w/ ProClip mount and cable $450 shipped | cruizin01 | Engine, Exhaust, Bolt-Ons | 1 | 08-14-2015 09:59 AM |
| Any idea to mount tablet on seat rail?? | Mikeez | Issues | Warranty | Recalls / TSB | 10 | 09-08-2014 01:28 PM |
| 8 inch tablet possible? | bgibbsunc | Electronics | Audio | NAV | Infotainment | 15 | 03-15-2014 09:36 PM |
| Amp wiring help + 3d printed tablet mount | transition | Electronics | Audio | NAV | Infotainment | 9 | 03-04-2014 09:41 PM |
