Old 08-22-2019, 04:29 PM   #59795
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes ethanol is bad for old parts but many of the carbs I had to rebuild were well before ethanol was ever used. Parts that are meant to be soaked in fuel all the time will break down pretty quick when exposed to air. Diaphragms are especially sensitive to both ethanol and good old oxygen. They tend to either get all droopy or turn as hard as a rock. Sometimes both!
I never really had to rebuild many carbs, most just needed a good cleaning unless they sat for a really long time or it was just the rubber tip of the float needle disintegrating. I didn't really deal with a lot of CV carbs though either. By the time I started wrenching things had mostly moved to fuel injection. Pre-FI Vmax's were always fun to work on. The carbs never wanted to stay in sync. I was always tempted to locktite the adjustment screws to stop them from rattling loose but I never knew how long it would be before I saw that particular bike again.
NoHaveMSG is offline
humfrz (08-22-2019)
Old 08-22-2019, 04:41 PM   #59796
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
Not sure how we ever managed to fix anything without a step by step manual and a YouTube video to follow! Although in fairness I guess a lot of the old stuff was easy to figure out and hard to screw up.
That and if the resources are available, why not use them?
ScoobsMcGee is offline
Old 08-22-2019, 05:33 PM   #59797
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Worst stock carbs ever: original 240z.
I had a pair of Carter AFBs on my Chevelle I rebuilt and spent days trying to dial in. Finally gave up an bought a pair of Holleys.
Sapphireho is offline
Old 08-22-2019, 06:46 PM   #59798
Didn't say otherwise. It was not a sarcastic remark I meant it.
Tcoat is offline
Old 08-22-2019, 08:28 PM   #59799
I found the two SU carburetors on my old MGB-GT the most challenging to keep in sync. I could have them right on in the evening with my car in my garage in CA and check them in the morning and they would be out of sync - and I didn't drive the car anywhere -
humfrz is offline
NoHaveMSG (08-22-2019), soundman98 (08-22-2019)
Old 08-22-2019, 08:43 PM   #59800
You shut your whore mouth.
Ultramaroon is offline
Old 08-22-2019, 08:55 PM   #59801
Sapphireho
Famous Potatoes
Sapphireho's Avatar
No.
Old 08-22-2019, 09:39 PM   #59802
Yep, I reckon.
And we didn't need a computer -
All we needed to tune an engine was a set of feeler gages, a dwell meter and a timing light.
I remember one fine day, under the shade of the maple trees in our barnyard, I had all my tune up equipment out on the fender of my car. My grandfather stopped over and asked me why I needed all that stuff. He said, "just listen to the engine, it will tell you when you have it right".
humfrz is offline
Old 08-22-2019, 09:50 PM   #59803
Yep, I reckon.
You had gauges, a dwell meter AND a tming light? You lucky bastard.
I had to make due with a duck feather, sticks and a rock
One of the best carb tuners I ever met used nothing but the sound and the smell from the exhaust.
Tcoat is offline
humfrz (08-22-2019)
Old 08-22-2019, 10:17 PM   #59804
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I still have my dwell meter and timing light. Still need the light for the porsche. Only car I have now with a distributor. I put a points eliminator kit in years ago.
Old 08-22-2019, 10:37 PM   #59805
Yep, I even had a vacuum gauge -
OK, I understand the duck feather and the sticks - but, what did you do with the rock? Oh, wait up, maybe you used it to tap the cover of the voltage regulator to release the points, or to tap the side of the carburetor to unstick the float, or to pound on the battery terminals to make better contact - ??
humfrz is offline
Old 08-22-2019, 10:39 PM   #59806
Sapphireho
Famous Potatoes
Sapphireho's Avatar
My wife officially hates simon. I showed the badger video to my wife and son, now they are all walking around the house, "badger, badger, badger.....snake, snake......mushroom......
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
EAGLE5 (08-22-2019), Spuds (08-23-2019), Ultramaroon (08-23-2019)
Old 08-22-2019, 10:40 PM   #59807
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I still have a vacuum guage.
humfrz (08-23-2019)
Old 08-22-2019, 11:08 PM   #59808
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Hundreds of hours of my life!
It's amazing how your hobbies really mellow you out.
When I visit Idaho, I'll be sure to stop by. How far from Emmet and how far from the Potato Museum are you?
EAGLE5 is offline
