#155 | |
- Andrew |
#156 | |
Drives: 15BRZ
#157 | |
Also, make sure your doing your final length setting with the suspension loaded. Every swaybar/coilover/endlink combo is a little different and can be annoying to get right. But your combo right now should be good as long as everything is properly torqued and the lengths are set correctly with the suspension loaded. - Andrew |
#158 | |
With stock swaybar, stock endlinks work just fine on SS1s. - Andrew |
#159 |
Drives: 2023 BRZ
Yes, great point. I indeed used an electric impact gun. That's what I should have said. I appreciate the correction.
Director of Rocky Mountain 86CUP
| The Following 2 Users Say Thank You to Pat For This Useful Post: | Racecomp Engineering (08-19-2019), strat61caster (08-19-2019) |
#160 |
Drives: 15BRZ
Thanks Andrew, i just got an email back from racer x , i didn't realize they were for lowered cars, when i installed the passenger SS1 coilover i had the adjuster dialed almost to the bottom of the strut so maybe that made it to tall? Sorry if this is a dumb question lol, i am new to this coilover stuff. i looking to be around 1 to 1.25 inch drop or so. i had about 1 inch of thread left at the bottom.
#161 | ||
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | KevBRZ (08-19-2019) |
#162 | |
Drives: Take a guess...
Hi Andrew, The car had my weight in it and its suspension was loaded on the scales when I set up the end links. I drove it and cycled its suspension on rough streets to verify there was no contact, which was why I was confused when the contact between the bar and the body started. All of the fasteners had been torqued and marked, and were still properly torqued when I checked them yesterday. The only thing that could have changed was the loaded spring height. I think I know where to start now - I'll put the car back on the scales to see if anything else moved. Thanks. |
#163 |
Drives: 15BRZ
end links
It was user error on the racer x end links
It was just a matter of fiddling around a bit with them, hoping to have them buttoned up by friday and rears to be done saturday! Racer x has been great BTW with communicating etc about the issues!! Great company!
| The Following User Says Thank You to KevBRZ For This Useful Post: | Racecomp Engineering (08-20-2019) |
#164 | |
Drives: brother from another mother
Definitely. 15ft/lbs isn't quite as much as people think it is. I used a small electric, harbor freight special w/ a 3/8th drive to torque it by tapping the trigger 2-3 times. Good to go. |
#165 |
I've been on stock suspension for the past couple weeks, and it's annoying.
![]() The SS1s definitely ride better. There's construction downtown (there's basically always construction downtown) and 1 area with a sharp edge due to resurfacing has me cringing before impact. I didn't have to do that with the SS1s. - Andrew |
#166 |
Persona Non Grata
Drives: '15 BRZ (WRB)
It's really too bad they can't/don't machine a flat into the very top of the shaft (out of the seal wipe zone) to let you secure the shaft. Even such a flat at the very top of the shaft (the threaded part) would help.
Slow is smooth, and smooth is fast
#167 |
Drives: 2013 FR-S Series 10
For me ride is not MORE comfortable, but definitely not much worse. For a LOT better handling/dynamics.
#168 |
@Racecomp Engineering
Okay, so I just installed these today. Very easy, straight forward install BUT... I did notice a slight manufacture defect. I don't think it's a biggie but wanted to make sure just in case. The passenger front coilover top slotted mounting points for the hubs isn't the same as the driver side. Top driver side bolt installed back same as stock but I had to flip the passenger side stepped bolt the other way in order to insert it. It's all torqued to spec and I don't see it being a big deal but just wanted to be sure. Thoughts? Last edited by Velisma; 08-29-2019 at 10:49 AM. |
| SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos | PMok | Northern California | 5 | 02-09-2015 06:26 AM |
| -0.5 for RaceComp Engineering | wrxneffect | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-04-2014 05:21 PM |
| Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 18 | 12-07-2013 11:20 PM |
| Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 05:17 PM |
| Racecomp website down? | Mikepage | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 04-22-2013 04:12 PM |
