Old 08-16-2019, 10:44 PM   #1
Violet
Violet's Avatar
Tuning my BRZ like a spastic
Hi Guys
I am new here, and have always been interested in efi tuning. I am looking for a little bit of advice.
I am sure this question has probably been asked several times but I cannot seem to find any results regarding the specifics of what i need to know.
So I have recently flashed my BRZ with one of waynes roms (based on the OFT base maps) with an e85 tune. It is running very well. so well in fact that the car is not knocking or pinging what so ever.
basically, the IAM stays at 1 no matter how hard i drive it. knock detection ignition advance also shoots straight to 5 (the max on this specific tune) when ever I go WOT.
I have been tinkering with ignition timing now for a few tunes. ive bumped the KDIA up to 8, and have increased the timing by a few degrees at higher engine loads between 5500 and 7000 RPM.
According to my logs, I am still maxing out the KDIA and my ignition timing is up towards the 36 degree advance region at Peak HP RPM at peak load.
My question is thus;
Am I ok to just, keep going?
should I just keep bumping up the timing slowly until I get some sort of ignition retard or no longer see my KDIA maxing out and then retard it a few degrees?
Do i need to mess with fueling, Valve control or any of that jazz?
If so, if anyone has any experience with tuning an e85 tune and could offer me some basic advice, you would really be helping a gal out.
Thanks in advance guys, i love these forums lots of helpful posts and friendly atmosphere
Violet is offline   Reply With Quote
Old 08-17-2019, 04:17 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I don't do my own tuning much, but @steve99 's signature block is a good place to start
EndlessAzure is offline   Reply With Quote
Old 08-17-2019, 04:28 AM   #3
steve99
Drives: FT86
Warning on petrol the engine is generally knock limited ie it will start to knock before you pass MBT ie max torque\power. On E85 its often not knock limited ie as you keep increasing timing the power actualky falks off bwfore you see onock. To tune for power on e85 you need a dyno to monitor piwer\torque
Old 08-17-2019, 05:55 AM   #4
Violet
Violet's Avatar
ah ok. that makes sense with what other information i have found. I will just leave it a few degrees higher than OTS.
thanks for your help
Old 08-17-2019, 06:51 AM   #5
Boomerang
86
Boomerang's Avatar
The vgi tool is awesome to use, it has a VVT tab also..
Old 08-19-2019, 08:15 AM   #6
Lantanafrs2
Drives: 2013 frs red
Wayno knows his shit. Not sure I would tweak his tunes too much.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
DarkPira7e (08-19-2019)
Old 08-21-2019, 03:58 AM   #7
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The openflash timing for E85 was already good, just needed some minor smoothing.
You only need to be concerned with getting the AFR right. After that just enjoy the car.
http://site.wayneroms.com:8000/#mafscales
brz, efi, ignition advance, tuning
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 08:53 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 03:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
