Old 08-01-2019, 12:56 PM   #15
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by jflogerzi View Post
You should be fine... Turbo or SC. Daily stage 2 is rated for 315 at the crank and I am sure that's conservative a bit. So at 10 psi you will be hitting 250wtq max would be my guess
Turbo. Thanks for the reassurance. Been doing a lot of research and this is the first thread I've come across with South Bend having issues.
Clueless
YamahaR86 is offline   Reply With Quote
Old 08-01-2019, 01:46 PM   #16
Olson1288
Olson1288's Avatar
Drives: 2014 DGM BRZ Turbo
Originally Posted by YamahaR86 View Post
Any updates on this? I'm interested in the South Bend Stage 2 Daily for boost @ 10 PSI as well but I'm only running it on 93 pump gas.
I haven't gone crazy or anything so far as to pull the clutch, but I did bleed it which seemed to help a bit. The fluid was pretty old and nasty looking, so I threw some new DOT-4 in there. Pedal feels a little better, I have not been able to replicate the issue yet, but I also have not been on the highway since. Might have to go for a cruise today...
Olson1288 is offline   Reply With Quote
The Following User Says Thank You to Olson1288 For This Useful Post:
YamahaR86 (08-01-2019)
Old 08-01-2019, 01:53 PM   #17
jflogerzi
jflogerzi's Avatar
Love mine. Doing great with my 210 IC on 10 psi using e85. Feels 100% OEM just a tab stiffer
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Brand *NEW* still sealed Clutch Masters FX-300 complete Clutch - SOLD JohnnieBoy Transmission and Driveline 5 12-15-2018 09:32 AM
2013 FRS buzz when clutch partially engaged/slipping bemgikim Issues | Warranty | Recalls / TSB 13 05-29-2017 10:47 PM
Driving under 3mph vs. slipping the clutch cat94 Engine, Exhaust, Transmission 31 02-14-2017 04:28 AM
new clutch slipping already? nickmerronesucks Engine, Exhaust, Transmission 12 10-07-2015 03:33 PM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 10:56 AM
