Old 07-30-2019, 01:43 PM   #29
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Originally Posted by tfp View Post
Dude, wtf is your problem? Stay the fuck away from me.
Sent from my SM-N950U using Tapatalk
This reminds me of a guy who emailed his co-worker saying "Don't you ever email me again." although they worked in the same department and had to work together on multiple projects.
Ignore the comments that make you feel bad and avoid responding to everything people say on the internet.
Back on topic...
They will all slip unless you go wider wheel / tire or a more performance oriented tire. All seasons are the jack of all trades and master of none, if you still have your stock wheels consider keeping those and have a more performance oriented set for dry weather.
MPS4S is a great tire though if you only have one set to daily on.
elitegunslinger is offline   Reply With Quote
Old 07-30-2019, 04:33 PM   #30
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I guess you also die by what you said? MPS4 =/= MPS4S
Apparently my old man eyes didn't see the "s" at the end. I sware I read just mps4.
Old 07-30-2019, 06:50 PM   #31
CSG Mike
CSG Mike's Avatar
Originally Posted by jflogerzi View Post
Not sure what's wrong with Indy 500s.. I have no problem driving my booted twin on there tires. Plenty of grip for street driving. I am not mashing the throttle every stop light.
There's nothing wrong with the Indy500; it's a great bang for the buck. The issue that the OP's C38 setup makes a bit more power than your Innovate/Sprintex 210 setup... and the Indy 500 may hold your power, but won't hold the OP's.
Old 07-30-2019, 07:48 PM   #32
jflogerzi
jflogerzi's Avatar
So far close to 300whp ATM with 69 pulley and e85
2013 Series 10 FRS #553
Old 07-30-2019, 09:33 PM   #33
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
But does he really need ultra grippy tires for JRSC though? Actually curious cause as far as I can tell from what I’ve read about the kit, the power is not all that overwhelming and arrives high up in the rev range
Depends on what you're comparing the JRSC to.
It absolutely hauls butt from 3000 and up. IIRC, the power delta at lower revs compared to the Edelbrock kit wasn't anything to write home about when comparing dynos.
With the A350, I'm not left wanting more when I put my foot down
mistople is offline   Reply With Quote
The Following 2 Users Say Thank You to mistople For This Useful Post:
CSG Mike (07-31-2019), StraightOuttaCanadaEh (07-30-2019)
Old 07-31-2019, 12:43 AM   #34
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
My RE71R sure don't hook at 300whp, let alone 360...
Maybe the fact that I’m auto helps? 1st gear may be a bit longer than the MT. Plus I am running 265s so maybe that’s it? Who knows. Either way it works for me just passing on my experience.
OzzyGT86 is offline   Reply With Quote
Old 07-31-2019, 01:52 AM   #35
CSG Mike
CSG Mike's Avatar
The innovate/spintex heat soaks really, really hard, and outside of anything other than an idealized dyno, it makes much less than 300whp.
Old 07-31-2019, 01:55 AM   #36
CSG Mike
CSG Mike's Avatar
At 400whp, even an auto won't hook with 265 RE71R, unless you're running very low camber and have them warmed up...
Heck, at 360whp I have 2nd gear spinning unless my 71R are fully warmed up.
If your car is actually hooking up... I need a ride!
Old 07-31-2019, 01:59 AM   #37
86MLR
86MLR's Avatar
I'm wondering how my 215/45 17 Hankook RS3's will handle 250hp.
I'm getting a modified AVO setup installed next month, 100% street car.
They are at about 50% at the moment, I might need to go 225 or 235 next, maybe, I'm limited by 8" rims, which, I'm not swapping because #RPF-1FANBOY.
I cannot see any issues with 235, and, 225 "should" be fine as long as I don't drive like a ****.
Old 07-31-2019, 08:20 PM   #38
OzzyGT86
OzzyGT86's Avatar
Let’s see when we can make that happen!
The Following User Says Thank You to OzzyGT86 For This Useful Post:
Old 07-31-2019, 11:18 PM   #39
Decep
Drives: 2013 FR-S Series 10
Anyone try taller gears in their twin after getting FI?
Old 07-31-2019, 11:54 PM   #40
CSG Mike
CSG Mike's Avatar
I'll be back in town on the 5th; what's your schedule normally like?
Old 07-31-2019, 11:54 PM   #41
CSG Mike
CSG Mike's Avatar
Boost + taller gears = awesome.
That's why I really like auto twins with boost!
mrg666 (08-12-2019)
Old 08-12-2019, 05:45 PM   #42
mrg666
pessimistic skeptic
mrg666's Avatar
Somebody said this and it is you again
The Following User Says Thank You to mrg666 For This Useful Post:
CSG Mike (08-12-2019)
Low boost with 225 tires Tectoniic Forced Induction 18 03-15-2016 04:31 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
