Old 07-20-2019, 02:13 PM   #1
brzultra
Drives: 2014 BRZ
black 17x7 or 17x8 dd wheels, prefer light
most likely will run stock tires, no track, no autox, just daily driving. Anything better under ~250/wheel than the RPFs I realize the 17x8s will handle wider tires, and big brakes, but not really necessary for me.
brzultra is offline   Reply With Quote
Old 07-20-2019, 03:07 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
I have the stock tires on 17x8, it’s terrible. Stick to 7” wheels if you don’t want to buy tires.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Busybee (07-20-2019)
Old 07-20-2019, 03:39 PM   #3
brzultra
Drives: 2014 BRZ
Thanks
I don't mind getting some new 225/40 or 45 all seasons.
Old 07-20-2019, 03:55 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
If you stated prefering light .. it somewhat hints to me, that handling feel might matter for you, including steering sharpness. Often some do slight stretch for that. Thus it makes me wonder, why all season tires are considered. A/S like winter tires, often are softer/sloppier, hardly enhancing handling feel.
Also wondering what so terrible with stock tires vs on wheel just inch wider ..
Old 07-20-2019, 05:08 PM   #5
brzultra
Drives: 2014 BRZ
Good questions, I do want the 8" rims in case in the future, I am able to track the car or put big brakes on. But, in the foreseeable future, simply a daily driver. Thanks for the questions and info.
Old 07-20-2019, 06:26 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I think most get it backwards...wheel choice should be determined by the tires. First you choose what tires you want to run THEN you choose the wheels to fit the tires... Tires size first, wheel fitment second.
If you want maximum responsiveness from the tires then you choose wheel width that corresponds to the tire tread width. Going thinner or wider in wheel width compared to tread width will influence handling differently.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 07-20-2019, 07:26 PM   #7
jflogerzi
jflogerzi's Avatar
Your not going to feel the weight difference. Just get the stock wheels powder coated or do plastic dip...
2013 Series 10 FRS #553
Old 07-20-2019, 08:14 PM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
https://www.ft86club.com/forums/showthread.php?t=105058
DuMa is offline   Reply With Quote
Old 07-20-2019, 09:46 PM   #9
Impureclient
Drives: 2015 FR-S
720form GTF1 17x8 15.5 lbs $223.00
The Following User Says Thank You to Impureclient For This Useful Post:
scotto79 (07-25-2019)
Old 07-20-2019, 09:50 PM   #10
brzultra
Drives: 2014 BRZ
not sure -
Others have noted differences from the stock ~21lb rims to ~15 or 16lb rims, and even measured higher whp on the dyno, and better mpg.
Old 07-22-2019, 06:30 PM   #11
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Tons of guys will be in the forum here trying to justify their purchases and all that so I'll just thrown in my two cents from the more extreme end of wheel fitment-- I run 18x9.5 Rays wheels on my BRZ with 255/35s all around now and the steering characteristics have hardly changed whatsoever. MPG is the same. WHP is the same... (despite many said I'd be ruining the car's performance by running such a wide wheel) I've also done adjustable coilovers and camber plates set at track specs and the car handles like a dream, even though my wheels are mainly for looks.
I would be fairly surprised if you could feel a concrete difference between two sets of same-sized wheels that are slightly different weights, especially since tires are what will have a much more noticeable performance impact. If you were a track ace pushing your car to the very limit with some RE-71rs on and then switched to an identical size forged wheel with the same exact tires for some hot laps directly afterward, then it's possible you may feel a small difference in responsiveness. In daily use though? I'm gonna go with 95% placebo.
If you're not going to track or AutoX, you won't really need ultra light wheels to be shaving lap times. Just don't get something super heavy is all. IMO I would spring for Rays, Works, Advan, WedsSport, etc... because the cheaper wheels on the market aren't really an improvement in quality over the OEMs anyways. Tons of people run RPF1s because they're high quality but are essentially one of the only solid wheels in that ~$250/ wheel price point. My personal recommendation for a 17" wheel would be the Weds TC105x in 17x9. Looks good & performs well, and track ready even if you add power later.
tl:dr - if you want performance on a budget, keep the stock wheels and get summer tires like the MPSS, Firestone Indy, or Falken Azenis FK510. If you eventually plan on tracking the car or adding power, spring for some 17x9 quality wheels & the aforementioned tires (or RE-71rs, Toyo R888R, etc. if you're really serious about track tires). If you care about looking good, 18x9.5 all the wayyyy (but you'll need to get your car lowered as well).
Sorry for the wall of text -- just didn't want to see ya buy a set of wheels now and then feel like you need to upgrade again later down the road.
Shizuka is offline   Reply With Quote
Old 07-23-2019, 10:54 PM   #12
Ernest72
Unsprung weight matters. I noticed a difference going to a lower weight rim, but it’s not earth shattering for DD. Do what you want and see how it feels. I don’t like adding weight if I can avoid it.
Old 07-23-2019, 11:24 PM   #13
jflogerzi
jflogerzi's Avatar
On a daily driven twin NA anything bigger than 225 on 17s with a semi sticky summer tire is Overkill and will remove all the fun from this car. Hell I daily drive my 275 whp supercharger twin on 17/225/45 Indy firehawks with 0 grip issues... now on the track completely different.
Old 07-24-2019, 10:35 PM   #14
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
You might take a look at Konigs. Some are flow formed , they are pretty well regarded by the track crowd, light, and a number of styles come in the size you're looking for.
I recently installed a set of 17x8 - 40 Ultraforms on my '15 BRZ. They weigh in at just under 17 lb. I sense a difference in performance but since I replaced the stock Mich o-rings with 225/45 Conti EC-Sport+ at the same time I have no way of disentangling the wheels' effect from the tires.
In all it shaved about 2 pounds off each corner. I'm happy.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
SOLD: Black STI Wheels 17x7 $650 TofuJoe Wheels and Tires 9 11-10-2017 01:49 PM
WTB- 17x7 wheels -Konig Daylite or other light wheels solort Want-To-Buy Requests 10 06-14-2015 05:38 AM
17x7 light replacement wheels solort Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-16-2013 08:46 AM
WTB: 17x7 +42-50 light (or light-ish) wheels Kido1986 Want-To-Buy Requests 0 11-11-2013 06:47 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
