#4215 |
Drives: gt86 FIRST edition #86
Did any of you have to replace the injectors?
#4216 |
Drives: 2014 Red Subaru BRZ
#4217 |
Drives: FRS
So, I was finally able to hook up my oil cooler again.
I had it disconnected because I couldn't figure out how to stop leaks from the sandwich plate adapter cluster f*** we have to use in order to have an oil cooler with the kraftworks kit. I tried everything short of devil worship to get the thing to work. Basically we use a spacer on the bottom, and a plate with a sensor on top of that, and then the oil cooler adapter plate on top of that, and finally the oil filter on top of that! So, 3 sandwich plates and an oil filter for grand total of 4 mating surfaces and something somewhere leaking in between. ![]() How did I solve it? I got me a fancy shmancy Skunk2 sandwich plate. I'm not sure when they came out with this thing, but I'm pretty sure it's relatively new to the market. It's basically one giant sandwich plate with an oil temp sensor bung, and the oil cooler adapter all in one! So now I only have two mating surfaces and zero leaks. ![]() I run the mishimoto oil cooler and had the male/female fittings from a motul sandwich plate which is 10AN on both ends. That doesn't fit on the Skunk2 plate. I had to purchase two 8AN male with 10AN flare adapters. The Skunk2 sandwich plate is 8AN. Oil cooler is 10AN. I'll edit this post with a pic once my wife gets back from the store with the car. Here's the links to this stuff if anyone is interested: Oil Filter Sandwich Adapter - '13-'16 BRZ/ FRS/ FT86 RaceFlux -8AN O-Ring Boss to -10AN Male Flare Adapter Fitting SKU: OM-08-10 these are nice because they have o-rings.
2018 Audi RS3 - Iroz
2005 Long Travel Tundra 4x4 2008 Long Travel Tundra 2wd |
#4218 | |
Drives: FRS
#4219 |
Drives: Raven FR-S 6M
The oring supplied with it is super low quality. I replaced mine with viton after it failed
Sent from my iPhone using Tapatalk Pro
“The World is Flat”
[||•]=(86)=[•||] |
#4220 |
No part number sorry. I just took the adapter plate to my local industrial supply and asked them to find a viton o-ring the same size. I have the old adapter so it may not be the exact same size as yours.
“The World is Flat”
[||•]=(86)=[•||] |
#4221 | |
Drives: FRS
#4222 | |
Drives: FRS
Thanks!
#4223 |
Drives: rx8. frs.
Anyone with this kit drift?
If so are you on the new updated belt? I’ve gone through 1 belt an event this season. Last event, belt lasted two laps. I’m still on the 20mm belt, I guess I need to upgrade, but want to make sure it would be worth it. I guess with the money I spent on belts I could have bought it already but I didn’t want the belts to go to waste. |
#4224 | |
BoostedBRZ
Drives: Turbo BRZ
https://www.ft86club.com/forums/show...3&postcount=23
#4225 | |
BoostedBRZ
Drives: Turbo BRZ
Something like this: ![]() As far as price goes... Mocal Thermostat - $170 Mocal Spacer - $16 (these two are sold together) ES20 (have to call BAT inc. they're the mocal contact for US - extended screw on) - $13.50 2 Mocal 1/2" BSP x -10 fitting - $12 each Mocal 90 Degree Socketless Push Lock Hose End -10AN - $12 Mocal 45 Degree Socketless Push Lock Hose End -10AN - $15 -10 Aeroquip Socketless Hose, Black - $80 Two remaining fittings on the oil cooler - ~$30 X-PSP-OIL-001 - Oil Filter Spacer for BRZ/FRS Black - $60 X-PSP-OIL-006 - Threaded Extender for Sandwich Adapter M20 (Oil Feed Pipe) - $25 Mishimoto oil cooler (probably should buy a setrab or mocal instead... mishimoto's fin density isn't the greatest) - $163 You can probably do it for a lot cheaper if you go with cheap hardware on amazon like fragola or whatever else is on there. But I wanted to best I could afford. It gets expensive when you start to price out the hoses if you want black nylon braided, fire sleeve protection, etc... so in total: $608
#4226 |
Drives: 1996 ST204, Series 10 FR-S
Hey guys,
Has anyone been in contact with Kraftwerks customer support? I have sent them 2 emails in the last 2 weeks and they have not replied to me. I'm not sure if they have disappeared or they are ignoring me. I just wanted to inquire about upgrading to the 30mm belt setup along with a high boost pulley. |
#4227 |
https://www.ebay.ca/itm/New-TP1200-8...0AAOSwYS9ZYQmw
^great deal on a new 30mm belt. double check the part number/item before you buy! |
#4228 | |
BoostedBRZ
Drives: Turbo BRZ
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
