Old 06-20-2019, 11:38 AM   #169
Originally Posted by AD55 View Post
I've been trying to figure this one out. The plug replace interval is listed as 5 years or 60K miles, whichever comes first.
Yep, that's what the manual says.
My 2013 FR-S has about 25,000 miles on it, and it's over 5 years old.
I'm not about to have the plugs changed before 60,000 miles, unless I get a misfire code.
Yes, I'm just an old man that drives my car up to the doctor's office and then on to the pharmacy/grocery store -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (06-20-2019), soundman98 (11-26-2019), sroby (07-16-2019)
Old 06-20-2019, 01:04 PM   #170
Impureclient
Drives: 2015 FR-S
I'm in the "proverbial little old lady" camp myself. I've put about 3500 miles each year so going by miles I'd be changing them in around 2032.
Even with 90% city miles, changing them at about 25k miles seems a bit premature. I'm thinking it'll be somewhere in between like 40k.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Dadhawk (06-20-2019), humfrz (06-20-2019)
Old 06-20-2019, 06:15 PM   #171
AD55
Drives: 2014 BRZ
That's exactly why I brought this up, as I too identify with that little old lady.
The car sits in the garage most of the winter months either due to ice and snow on the roads or because there's salt all over the roads to get rid of the ice and snow.
I do sometimes start and run it up to operating temperature or maybe just sit in it, run it through the gears, and imitate the sound of a boxer engine.
No doubt about it, I've got to move south before I lose what's left of my mind or are just too old to climb in and out of the BRZ.
AD55 is offline   Reply With Quote
Old 06-20-2019, 09:19 PM   #172
Now is the time to practice the old "exit roll". Getting in isn't too bad, "flopping" out can be embarrassing -
Old 06-21-2019, 12:21 AM   #173
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I chuckled at this. Because if the plugs degraded over 5 years without usage then we could probably expect the rest of the car is simply dissolving in our garages as we speak!
SCCA T4 - FRS
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
Dadhawk (06-21-2019), humfrz (06-21-2019), soundman98 (11-26-2019)
Old 07-10-2019, 12:29 AM   #174
LerpK
Drives: 2014 Scion FRS
I am about to tackle this job here in the next couple weeks. I see some people saying that jacking the engine up helps create more room, and others saying it didn't help. Does it help that much or doesn't it? Also, do the engine mounts need to be removed or loosened to jack the engine up, or just the few things already mentioned previously, like intake, alternator hard line, etc.?
LerpK is offline   Reply With Quote
Old 07-10-2019, 03:43 AM   #175
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I did the same thing this dude did. Takes time, just be patient. Even with my fat gorilla hands I did it.
Old 07-12-2019, 05:09 PM   #176
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
If you choose to raise the engine any appreciable amount, you will have to undo the single bolt from the mount to the frame on each side of the motor.
In my opinion, it is definitely not worth it to lift the engine for a simple plug change. I just did it for the second time and, if I can recall, these are the tools I used: short sockets (10, 12 mm), deep socket (14 mm), very short extension (~1 inch), short extension (2 inches), long-handled fine toothed ratchet (head as narrow as you can find - I like the narrow Craftsman ratchets), magnet on bendable/extendable stick (I use a Husky "penlight/magnet" combo tool I found at Home Depot), and a small mirror of some variety.
You will have the most trouble pulling the #4 plug (driver's rear) as the frame is very tight and you have to disassemble your tools to get the deepwell 14 mm socket out. Strong fingers will help you. Or you can use a set of long-handled pliers to grip the extension while blocking the socket from leaving the plug hole.
You will be in great pain while removing the #2 plug (driver's front) as the HPFP assembly above it is sharp and hate-filled. It will cut you. You will bleed all over your fuel lines. You will contemplate selling your car.
In terms of access, you will need to remove two things, the injector ECU on the passenger side and the HPFP heat shield on the driver's side. For the ECU, don't unplug it, you'll regret it. Just twist the ECU towards the floor and stuff it next to the battery. This will limit the amount of tension you put on the harness. For the heat shield, it's two 12 mm bolts - use a magnet to control the rear bolt as it is way down on the block and easy to drop. It is very heavy and very sharp and will damage harnesses and paint. Carefully maneuver it back towards the firewall under the left chassis brace and then pull it up on the front side to clear the fuel lines. Then carefully extract it towards the front at a 45 degree angle.
Good luck and God speed. If only Subaru had cut a couple access holes in the frame to allow direct access via the wheel wells....
theadmiral976 is offline   Reply With Quote
The Following User Says Thank You to theadmiral976 For This Useful Post:
ddevl_86 (02-27-2021)
Old 10-12-2019, 08:20 PM   #177
evan_calgary
Drives: 2014 Scion FRS Hot Lava
Just finished this today. Thanks for the write up.
Based on what Toyota charges to get it done I thought it was not a hard nor long job. 3 hours including a trip to get tools and some messing around.
I wouldn't both jacking up the engine.
Definitely remove the torsion bar, the plastic clamp for the hoses and the whatever than heavy black metal cover is on the driver's side.
If there is anything I can recommend, don't click in your ratchets. The few times I did I wasted more time getting them off than anything else.
It is tight in there but the people that built this car made it just work.
evan_calgary is offline   Reply With Quote
Old 11-24-2019, 09:56 PM   #178
LerpK
I completed this with a buddy and it honestly wasn't as bad as I was expecting. It's a pretty easy, straight forward job. It is just time consuming with the limited amount of space to work in.
I didn't need any special tools either, just used a 3/8ths ratchet, a 6'' extension with the shorter "spark plug" extension attached to that, deepwell socket, small flathead screwdriver to help disconnect the socket from extension, magnet with rotating head to grab the plugs, and most importantly some rags stuffed down the sides to catch falling things (vital).
Old 12-22-2019, 03:48 PM   #179
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I'm at 171k on my daily/mostly highway driven 2013 BRZ and while the car seems to run fine, it's something I am going to do in the spring. Is everyone for the most part following what this guy did? Definitely not planning on jacking up the motor.
B-R-Z is offline   Reply With Quote
Old 12-22-2019, 10:00 PM   #180
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
That's the way I did it. Takes time but it's doable
Old 12-23-2019, 02:50 PM   #181
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I'm at 50k miles and planning on doing mine this way at 60k. I have a size medium-large hand so hopefully that plays to my advantage.
Clueless
YamahaR86 is offline   Reply With Quote
Old 12-24-2019, 06:49 PM   #182
toast
Drives: 14 BSP Edelbrock BRZ
My biggest tip is what someone said above, don't push your sockets all the way on your extension. You will spend more time separating them than anything else.
Also, use a length of fuel line to thread them in - slide the line over the plug, feed it in the hole and then spin the line and the plug will find its way into the threads. Only time you need the socket is to tighten it down.
toast is offline   Reply With Quote
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 10:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 04:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
