Old 07-02-2019, 09:20 PM   #8513
stockysnail
Just the tip
stockysnail's Avatar
I had an issue with if I remember correctly was cylinder 4 not firing. It ended up being the water pump power plug wasn't plugged in all the way. I had to really push hard to get it to snap in all the way. It's daisy chains/plugs into the injector power cord. I went through a ton of other stuff before realizing this and even stripped bolt hole threads where my fuel rail mounts trying to get stuff apart. Super frustrating. Fine now. I made sure to bend the plug just a little so it wouldn't come loose.
If you have the intercooled version this may be something to look into.
The Following User Says Thank You to stockysnail For This Useful Post:
kev0 (07-02-2019)
Old 07-02-2019, 09:29 PM   #8514
kev0
Drives: '14
I'm non-intercooled .
kev0 is offline   Reply With Quote
Old 07-02-2019, 09:38 PM   #8515
kev0
Drives: '14
My installer believes that the reason for my problems is because of the manifold gasket. I am in search for some replacement manifold gaskets. Would anyone know where to get them besides contacting Sprintex?
Sizes for those gaskets are 63.17 ID x 2.62 CS
Old 07-02-2019, 10:33 PM   #8516
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by kev0 View Post
Yes, manifold gasket. They were new but I guess they got dirtied up during the install. I will need new ones. Do you know where I could pick some up? Or do you know the sizes of them?
My installer believes its the reason why Cyl 4 is misfiring and giving me vacuum leak symptoms. Cyl 4 is the only one that looks like that.
If they aren’t cut up or scraped and brand new they are probably fine. Pull them out inspect clean off as necessary. The engine looks super dirty, you need to clean off all that crud. Will definitely not allow the manifold/gasket to seal properly. It doesn’t look like that crud is on the manifold so it was probably already there before, your installer should have seen it and cleaned it all
Off. Also inspect and clean off the manifold portion make sure no visibly large scrapes/scratches that would also cause leaks if so you’ll need to dremel it down to a flat smooth surface.
When installing those gasket/o-rings use grease or vaseline to keep from ruining them.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-02-2019)
Old 07-02-2019, 11:23 PM   #8517
kev0
Drives: '14
Yup, going to do a thorough cleaning before installing em. Is it possible to get a misfiring code due to gaskets not sealing correctly?
Old 07-03-2019, 12:17 AM   #8518
86TOYO2k17
An abundance of unmetered air (IE a leak post maf sensor) could cause a misfire and the fact that it is one cylinder it would make sense that the gasket around that cylinder is leaking letting extra air in under vacuum (IE at idle when boosted) only that cylinder would be effected. But it may not be a faulty gasket and just a dirty surface and or scratched/scraped surface not allowing proper surface mating. Also be extra careful not to get any of that inside the cylinder head.
A thorough inspection and cleaning of the surfaces and gaskets. Then double check every single hose is fully pushed on and clamped. Make sure brake booster is installed correctly (this could be the other fault code) . Go over every install step and thoroughly read and fully understand exactly what it wants you to do and why before moving onto the next step. Then reflash tune. And give it another shot.
kev0 (07-03-2019)
Old 07-03-2019, 02:04 AM   #8519
kev0
Drives: '14
I appreciate you!!
Old 07-04-2019, 05:05 AM   #8520
kev0
Drives: '14
The guy that did the install on my kit recommended the WRX/STI PCV valve because the ones in our cars leaks boost since it wasn't meant to see FI. What do you guys think? Are you guys using any sort of PCV valve?
Old 07-04-2019, 10:30 AM   #8521
sqd
sqd's Avatar
Drives: '13 SWP GT86
Don't bother. That PCV is before the boost pressure in the system so it doesn't experience any boost at all. With a turbo on centrifugal SC it's different, since it forces air through the intake system and pressurizes the PCV.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
The Following 2 Users Say Thank You to sqd For This Useful Post:
kev0 (07-05-2019), sroby (07-04-2019)
Old 07-04-2019, 08:55 PM   #8522
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Anyone got specs on charge air with/without laminova intercooler? I'm thinking about getting one, and want to justify spending 1.5k.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 07-04-2019, 09:15 PM   #8523
jflogerzi
jflogerzi's Avatar
What are you doing with it? Do you have access to e85? Any track work?
2013 Series 10 FRS #553
Old 07-04-2019, 09:23 PM   #8524
riboyster
riboyster's Avatar
Probably won't track it very often. Been boosted for like 4 years now and haven't seen a track yet. Just short sprints on my daily commuting. Unfortunately, no e85. 92 oct.
Old 07-04-2019, 09:41 PM   #8525
jflogerzi
jflogerzi's Avatar
You might gain 15-20whp but it will stave off heatsoak a bit longer. Not sure it's worth it. Let others chime in.
Old 07-04-2019, 11:25 PM   #8526
riboyster
riboyster's Avatar
Ahh f$%k it. Just ordered one. All of my research has led me to believe that the pros outweigh the cons.
Still though, I would be interested in anyone else's feedback.
The Following User Says Thank You to riboyster For This Useful Post:
jflogerzi (07-04-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
