#8499 |
Drives: '14
Well I'm certain there is a leak somewhere. I just can't find it. Performed a smoke test and soapy water test. Found a couple of leaks but we have since fixed it but the problem still persists.. I'm at the point where I'm about to uninstall the kit and reinstall it. Can a leak cause a spark plug to misfire?
#8500 |
Check install. My tune from Moto East was really good out of the box. Did you give Mike your complete list of modified parts?
2013 Series 10 FRS #553
#8501 |
Drives: '14
#8502 |
Be patient and take your time. Its well worth it in the end. Walk away for the night and start fresh in the morning.
| The Following User Says Thank You to jflogerzi For This Useful Post: | kev0 (07-02-2019) |
#8503 | |
Drives: 2017 toyota 86
Then it would most likely either be from a leak someplace. Make sure every single hose has a tight secure hose clamp and or zip tie on both ends and the hose is fully pushed on and seated. Misfires can also often be caused by dirty, clogged injectors, or the injector seal was damaged/pinched on install, did he use grease on the injector seal when installing to prevent damage like the manual suggests? Or if he did, did he use too much and get some In the injector clogging it. or make sure the injector harness plug fully seated and connected properly. After resolving any issues/leaks are you clearing all the codes before starting back up and testing it? Also just to make sure it’s not something super obvious... are your map and maf sensor stock? Are they plugged in? Did you make sure not to pinch and damage the o rings? |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (07-02-2019) |
#8504 | |
Drives: '14
#8505 |
Drives: 14 BSP Edelbrock BRZ
A leak will show up as large (20% or so) positive short term fuel trims at idle. Do you have an idle log? If it is very bad they will be maxed (+29%) meaning you are dumping fuel to compensate for the leak and you can dump so much you get misfires.
#8506 |
Drives: '14
I think I know why my car wasn't starting up. I seem to be missing a hose and a valve from step 5.18 in this manual: https://www.innovatemotorsports.com/...wvMeUjixoZNJM0
Also, does anyone know the differences with kits with part 6010, 6011 than the 6012,6013? I ask this because I was following a different manual during the installation that didn't mention any of the parts from the first manual. This was the manual I followed: https://www.innovatemotorsports.com/...T86_Manual.pdf My kit is nonintercooled which is why I followed that manual.. For those with the kit installed, do you guys recall doing step 5.18? Last edited by kev0; 07-02-2019 at 07:05 PM. |
#8507 | |
You should be using sprintex install manual. Innovate stopped supporting this kit long ago. Sprintex has updated the install manual. Also 5.18 is the brake booster. You just reuse your hard line and add on a longer hose but it needs rerouting, I explained this previously and told you to double check it... take a few pictures of your install and brake booster line. Last edited by 86TOYO2k17; 07-02-2019 at 08:33 PM. |
#8508 | |
Drives: '14
#8509 |
Drives: '14
Also, my installer took everything apart. He believes that it could be an issue with my intake gaskets which is why cylinder 4 isn't firing correctly.
https://imgur.com/a/fH0d4nI This didn't happen before the SC. Could it be a faulty installation with a leak somewhere in the hoses or are my gaskets done? |
#8510 | |
#8511 | |
#8512 |
Drives: '14
Yes, manifold gasket. They were new but I guess they got dirtied up during the install. I will need new ones. Do you know where I could pick some up? Or do you know the sizes of them?
![]() My installer believes its the reason why Cyl 4 is misfiring and giving me vacuum leak symptoms. Cyl 4 is the only one that looks like that.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
