Old 06-16-2019, 03:54 PM   #1
hukdizzle
Drives: 2013 Subaru BRZ (WRB)
RCE Tarmac 2/17x9 RPF1 Clearance?
Hi Everyone,
Recently installed RCE Tarmac 2 coils and I am looking to get into a lighter/wider wheel and was hoping to get some input on the tire/wheel clearance for the following.
RCE Tarmac 2 (Raceseng Cascam Top Mounts)
17x9 Enkei RPF1 +45mm Offset
245/40/17 DOT Tire (Likely an RS4 or something along those lines)
Installation wise, the car has a crash bolt installed up front from prior classing and since the top hole of the strut mount on the tarmac is slotted I will be maxing out the static camber via that, and then adding additional camber via the top mounts to achieve necessary track oriented camber. I am looking to achieve the following alignment/ride height with adequate strut/tire clearance.
Camber F : -3.5'
Toe F : 0" Total
Camber R : -2.2'
Toe Rear : 1/16" Total
Caster F : 7.0'
Ride Height : Approx 13.56" from top of fender to center of wheel hub. Slight rake with the rear being a 1/16" higher than the front. Car will be corner balanced so static corner heights may change slightly.
Thanks for the help!
hukdizzle is offline   Reply With Quote
Old 06-16-2019, 09:52 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Clearance to the strut should be no problem, neither should the targeted camber, I have rubbing on the inner fender liner with those wheels so I use a 5mm spacer with extended studs to prevent that from happening. +35 to +40 is no issue, might be able to get away with a 2-3mm spacer to prevent rubbing, not sure. Edit: +35 has no rubs on the fenders unless you go low enough for any tire to rub.
ineedyourdiddly
Old 06-17-2019, 02:39 PM   #3
hukdizzle
Fantastic man thanks, that's what I was looking to hear. Can you advise where or how you heard about the +35 having no issues at this measurements?
Old 06-17-2019, 02:49 PM   #4
strat61caster
http://www.ft86club.com/forums/showthread.php?t=15007
ineedyourdiddly
Old 06-21-2019, 05:53 AM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
If you're going for as much as -3.5º of front camber, you'll probably prefer +35 offset over +45, as +45 will be too deep in the arches.
See https://www.ft86motorsports.com/wheelitfit/
ENKEI RPF1 in 17x9 +35 & Team Dynamics PR 1.2 17x9 +35. PM for FORUM PRICE! OAKOS Automotive Groupbuys 145 12-14-2016 03:54 PM
NorCal FS: Enkei RPF1 18x9.5 +38 Tarmac Black Edition TRDGriffon Wheels and Tires 2 11-07-2015 07:11 AM
RPF1 17x9 +35 & AP endurance BBK clearance? tnle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-28-2014 07:47 AM
TC105N or RPF1 17x9 - Brake clearance diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-28-2014 12:19 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
