#43 |
Drives: 14 BSP Edelbrock BRZ
| The Following 4 Users Say Thank You to toast For This Useful Post: |
#44 |
Wes
I think so as well. Although even at 33 I do alternate between back seats up and down to get more or less noise. My trunk is stripped as well so there's quite a lot of noise with them down.
Instagram: @gt86ws
#45 |
Drives: jrsc_brz
I have a jrsc, it's definitely audible starting around 2500rpm, but sometimes I wish I had a turbo so I could be all psh psh brap brap flutter flutter pop pop bang. Seriously tho, deciding on/finding the best tune/dyno shop is the most important thing
| The Following 3 Users Say Thank You to HaXx For This Useful Post: |
#46 | |
Drives: 2017 Toyota 86
Can’t you basically give the JRSC a blow off sound by messing with the bypass valve? Speed Academy on YouTube seems to have done it Sent from my iPhone using Tapatalk |
#47 |
Drives: jrsc_brz
Agree, imagine if every 200hp car on the road was going around straightpiped. Ugh. Imo, nothing worse than a slow car that's loud. Like full exhaust, stock engine. That's why I give props to OP for committing on boosting. "But full exhaust gives you power, and I have a CAI"!
#48 |
I've been planning on going with JR simply because it's so well proven at the track, and that's where I want the reliability and durability. AFAIK, no other type of FI kit (PDSC or TC) has been able to manage heat saturation for more than a handful of laps. Admittedly I haven't done much research in the last couple years, but I'm still not at a place to make the purchase so if the Harrop kit or some turbo kits are trackable for 30 minute sessions then I have some research to do.
| The Following 4 Users Say Thank You to wheelhaus For This Useful Post: |
#49 |
Drives: 2017 BRZ (Sold), 2023 GR86
I opted for the JRSC for a number of reasons: Simplicity, top end performance, cost, sound effects, and low weight.
List is in order of importance to me. |
#50 | |
Drives: 2014 BRZ Limited
In my opinion go with the Edelbrock; the Rotrex units aren't made to be rebuilt (you can but the manufacture doesn't support this). |
| The Following User Says Thank You to elitegunslinger For This Useful Post: | 86TOYO2k17 (06-10-2019) |
#51 | |
I CANT MAKE A DECISION!!! Jrsc or edelbrock.
I’m no expert, but from what I can see, a brand new Rotrex C30 is only around $2000-$2300. there are plenty of people on the forum and elsewhere that seem to have minimal issues with their units 2-3 years in , I don’t really see how this is a big issue. Sent from my iPhone using Tapatalk |
#52 | |
Weight Weenie
Drives: 15 FR-S
Vortech is supposed to run the coolest from what Ive read. Don`t ask me to find it lol |
| The Following User Says Thank You to new2subaru For This Useful Post: | wheelhaus (06-10-2019) |
#53 | |
| The Following User Says Thank You to elitegunslinger For This Useful Post: | HachiRokuX (06-27-2019) |
#54 | |
Drives: 2017 BRZ
Also, the PDSC kits use an OEM blower drive. |
| The Following User Says Thank You to gtengr For This Useful Post: | wheelhaus (06-17-2019) |
#55 | |
pessimistic skeptic
Both turbo and PDSC cars are tracked successfully. For example, Michelle Abbate with Edelbrock, CSG Mike with turbo tracked their cars successfully in the full race scale. So it is possible to track with turbo and PDSC if you build properly (expensive). But, you are right that JRSC has the best track record. Installation of JRSC is very simple, straightforward, and with minimal modifications in the engine bay. It almost clicks in place without any cutting, drilling. JRSC has completely independent oil/cooling system with no risk of blowing coolant into intake. This happened with PDSC (there are posts in FT86Club forum) in some cases and they ended up with a blown engine. JRSC does not tap into engine oil circuit or reroute exhaust pipes in the engine bay to increase temperature like some (all?) of the turbo kits. But many drivers prefer (not me) low-rpm torque which gives instant acceleration by just pushing the throttle. JRSC torque curve is not flat; it is a linearly increasing torque curve with rpm but helps with engine reliability as high torque at low-rpm is an impact load on engine components. With proper down-shifting, low torque at low-rpm is not an issue for me; I think learning to down-shift properly gives a better feeling of driver engagement actually. I have not had any reliability issues with Rotrex unit. In case needed in the future, replacement of compressor unit is not that cheap but very easy. After driving more than 2 years and 20K miles with JRSC, I have no regrets. |
| The Following 4 Users Say Thank You to mrg666 For This Useful Post: |
#56 | |
Steve Bodalenko
Drives: Toyota 86 GTS
They make a shit load of HP parts other than the SC for the 86 and it's all made in house, brilliant and highly respected. Certainly not cheap though! Given the exchange rates between the $US v $AU makes it a third cheaper than the price we pay. |
| The Following 5 Users Say Thank You to Bodalenko For This Useful Post: | ElijahF (12-07-2019), jcw99 (08-18-2019), The Racers Line (07-02-2019), Ultramaroon (06-29-2019), weederr33 (06-29-2019) |
| Edelbrock vs JRSC for track | Hades | Forced Induction | 21 | 02-21-2018 03:30 PM |
| Anyone of JRSC or Edelbrock? | tian105 | Mid-Atlantic | 11 | 10-02-2017 12:56 PM |
| Help me make a decision. Please! | HillCountryGuru | Electronics | Audio | NAV | Infotainment | 11 | 01-28-2013 12:07 PM |
| How did you make the decision to buy an 86/brz? | Dazza | AUSTRALIA | 30 | 09-06-2012 08:33 AM |
| How will you make your decision? | Jeris@CatoMoto | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-01-2011 12:13 AM |
