Old 09-24-2016, 10:40 PM   #29
adjusts
adjusts's Avatar
Drives: 86
Can't wait to see it man
adjusts is offline   Reply With Quote
Old 11-05-2016, 01:37 AM   #30
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
With the waiting game still going on for many parts that I ordered months ago, there is one positive update that I can do. I've officially joined the bagged group. I'm running AirLift Performance system w/ 3H management system. I will post pictures up soon.
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 11-05-2016, 02:27 AM   #31
Michael
Lovin' the Low Life
Michael's Avatar
Here are a couple of pictures for now until I get time to do more in proper lighting.
Old 12-13-2016, 01:33 AM   #32
adjusts
adjusts's Avatar
Drives: 86
did not disappoint.
Old 02-13-2017, 04:51 AM   #33
Michael
Lovin' the Low Life
Michael's Avatar
Since my last update, there have been some changes to my build and a slightly different direction that I originally had planned. I have removed the AirLift system and swapped back to coilovers. The air bags were too soft for my liking and I did not want to run higher psi in them. I went with the Fortune Auto 500 Series coilovers and will be awaiting their Air Piston Lift System once it is tested and comes out for the 86 platform. I have also installed the Perrin sway bars today for both the front and rear (19mm/16mm respectively). I have not truly tested it yet to see which stiffness setting that I prefer it on but I wanted to keep the ratio similar to stock for now. Finally, I had installed the ADVANS TCIII wheels. After installation, I noticed that the front fender clearance is about 1/2" higher than the rear. The front coilovers have plenty of thread left to lower it more so that will be fixed next weekend and then I may slap on 10mm spacers in the front and rear to bring out the wheels a bit more. I am running less negative camber all around so I will not be as low as when I had BC Racing Extreme Low coilovers. I am okay with that due to the end goal for my build.
The Following 2 Users Say Thank You to Michael For This Useful Post:
beltax90 (04-29-2020), haimichaeltran (02-13-2017)
Old 06-13-2019, 09:37 PM   #34
Michael
Lovin' the Low Life
Michael's Avatar
Geez, I really don't update this thread at all. I need to get on that since the car goes into the paint booth tomorrow and a lot of work was done to it.
Check out my Instagram, @ frsmichael
Old 01-03-2020, 09:20 PM   #35
Michael
Lovin' the Low Life
Michael's Avatar
I have updated the original post on what I've done and will soon be revealing the build and color at the end of the month or early February. Dropping the car off soon to have some paint protection installed (XPEL and ceramic coating).
Old 04-29-2020, 12:09 PM   #36
Michael
Lovin' the Low Life
Michael's Avatar
Update on my build. More pictures up on IG @frsmichael
2014, frs, scion, scion frs, whiteout
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
The Saga of OLAF, 2014 Monogram Whiteout Scion FR-S wulfstan Member's Car Journals 83 12-12-2019 01:24 PM
DKX 2014 Whiteout FRS Build - Socal dkx64 Member's Car Journals 130 01-24-2018 01:37 AM
2014 Scion Racing Road Race Build MicheleAbbate Member's Car Journals 148 04-22-2016 09:13 AM
Scion tC and FR-S 2014 Monogram Series to be available in early 2014. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 655 01-10-2014 06:03 PM
