Drives: 2016 brz limited
Rear end shake BRZ
In my BRZ , When starting from stopped or slow speed’s turning left or right sharply, the rear end will judder/shake a little bit until I straighten it out, or pick up a little speed only shakes for a second. Could this be the rear LSD? Is it normal? It is an automatic.
Sent from my iPhone using Tapatalk Last edited by brzboy; 06-11-2019 at 01:00 AM. |
#2 |
Rust bucket enthusiast
It could be a lot of things, but it's a quick check to drain the fluid from the diff ( if there is any) and fill it with some new goop. Couldn't hurt to check!
Other things - Check yo lug nuts boi Check you axles and make sure the boots aren't torn and leaking fluid Are you sure it's the rear? See if your swaybar endlinks are attached properly Check your strut mount bolts |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | humfrz (06-11-2019) |
#3 | |
Well it has done it for the entire lifespan even brand new Sent from my iPhone using Tapatalk |
#4 |
Drives: Dodge Patitas
I do remember a bit of shudder when it was new, and maybe still does it a bit accelerating out of close turns. However, I'd recommend changing diff oil as mine got a bit better when that was done. I think it's normal behavior for the LSD.
Sent from my Pixel 2 using Tapatalk |
#5 |
Thanks
My thoughts is it is the diff working, since you said it happened since new.
Otherwise if you are running with traction on it is very intrusive especially if you are adding throttle in a turn. The brake actuation may sound like a judder. Doesn't sound like anything is wrong from your description.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | brzboy (06-11-2019) |
#6 | |
Thanks everyone it was just TRACTION BEING ON STUPID ME !!! Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to brzboy For This Useful Post: | humfrz (06-11-2019) |
#7 |
| The Following User Says Thank You to humfrz For This Useful Post: | brzboy (06-11-2019) |
| 60-70 mph shake | Jonbonilla | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-06-2019 02:39 PM |
| TRD Griffon Second Shake Down | zephyr69 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-08-2013 08:39 AM |
| Harlem Shake | Simpleviet | Northern California | 14 | 02-14-2013 01:23 PM |
| Rev Shake | injuryexpert | Issues | Warranty | Recalls / TSB | 0 | 11-21-2012 10:56 AM |
| First Weekend Shake down. | feldy | Tracking / Autocross / HPDE / Drifting | 8 | 06-11-2012 01:24 AM |
