Old 06-03-2019, 02:28 AM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Lightest Battery w/o Tender in CA
So, what's the best, easiest to mount battery with the most weight reduction?
I live in California, and I'm really forgetful so no tender.
I drive my car 4-5 days a week, so least maintenance the better!
Lastly, whatever pounds shaved off would be appreciated as I'm a fat ass. Easier to buy my way out than lose weight
Odyssey PC925 a straight swap?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 06-03-2019, 03:20 AM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
DELTRAN BTL24A360C
its what Goodwin Uses
Clutch Dog is offline   Reply With Quote
Old 06-03-2019, 09:43 AM   #3
86TOYO2k17
Drives: 2017 toyota 86
LFX36L3-BS12 - 25lbs weight reduction. Pretty much has the most weight reduction and the highest CCA for a lightweight battery. No tender needed unless car sits for a long time in cold weather.
Most lightweight batteries should be tendered if sitting for a long period of time in cold weather, or if your car has a constant draw when turned off from something like alarm system, or remote start. In CA temps shouldn't be a concern, just hook up to a tender if you know your not driving for 5+ days, or you could just disconnect the battery terminals.
Old 06-03-2019, 12:57 PM   #4
ka-t_240
I have a 12lb braille battery. If you drive it daily, you are fine with out a tender. Car starts fine on corn in 40* temps.
I do have a tender hardwired to the car as it is not my daily, so the tender is just to insure it keeps everything happy.
ka-t_240 is offline   Reply With Quote
Old 06-03-2019, 01:18 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I daily drive a PC680 short commute 20-30 minutes one way if I take a detour, sometimes it sits over a weekend, it's sat for a week before, no issues so far, it will be 2 years old in October. I've never hooked it to a tender, the battery has never been dead on me, PC925 is probably overkill but a surefire bet if you're nervous. I bought the smaller battery parts from Japan but they're still oversized for the battery and I've just got the bracket cranked down so it doesn't move, someone posted a parts list in another battery thread, it's like $40.
I'm going for the 5lb Shorai (or similar) when this thing dies as I've heard pretty good things and the PC680 has been flawless. I'm lazy so I'll probably spring for somebodies fancy mounting brackets which will suck but it's a one time purchase.
This thread is however reminding me I should probably buy a jump pack soon... Just in case.
ineedyourdiddly
Old 06-03-2019, 03:07 PM   #6
SmartedPanda
Thanks everyone for the suggestions, I was looking at smaller batteries such as the PC925 and the B2015.
These look like they need custom mounts to use so far, and there's not much documentation besides buying stuff at hardware stores or custom mounts that are about the same price as the battery...
1. Can AGM be jumped like normal?
2. I have an old battery tender that's like 20+ year old, any issues using this?
3. Which one is the easiest to drop without a custom harness?
Old 06-03-2019, 03:19 PM   #7
teetsdownlow
Drives: 2015 FRS
For my rx8 I used a deka 30l and it has worked fantastic. I did use a new battery bracket for it as well for a direct replacement. Haven't had any problems with bay area temps. Be mindful that these batteries don't have much of a reserve so understand that going into the purchase. Also, sometimes the terminal ends are too small/big for powersport batteries so check into that as well
There's trickle chargers out there that fit into the dead buttons where fog lights or a trunk button may be. Noco genius is a fantastic trickle charger
PS I know the frs doesn't get as hot as the rx8 but if looking into Odyssey I would get the fmj version
teetsdownlow is offline   Reply With Quote
Old 06-03-2019, 04:18 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
1) Yup.
2) I've got a BatteryTender JR that came with my '98 BMW bike. Still works fine.
-- One of the SAE terminals got stretched a bit once and I have to wiggle the terminal a bit to get steady lights. Works fine then. I'll have to fix it, someday.
3) Some parachute cord wrapped a few times around would do it if you're good with knots. To each their own.
Old 06-04-2019, 02:10 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's not the harness that is an issue it is making sure you have the right terminals.
I am on a PC680. Car is only driven about 3 days a week. No tender, no issues.
Old 06-04-2019, 10:38 PM   #10
SmartedPanda
Could you expand ?
Old 06-05-2019, 12:15 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Could you expand ?
A lot of the smaller batteries have screw type terminals. You need to put SAE posts on them.
https://www.amazon.com/XS-Power-586-...y&sr=8-2-fkmr0
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
strat61caster (06-05-2019), why? (06-05-2019)
Old 06-05-2019, 02:37 PM   #12
SmartedPanda
Yeah, that's the easy part so far, I'm just confused how everyone mounts it without it moving everywhere or paying the same cost as the battery.
Thanks for the info!
Old 06-05-2019, 02:50 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I modified my stock bracket.
Old 06-05-2019, 02:51 PM   #14
SmartedPanda
Can I ask how you personally did it? I might just pull the trigger cuz there's a sale at Jeg's right now.
"Best" Battery Tender for long term BRZ storage? joro2 BRZ First-Gen (2012+) — General Topics 10 10-02-2017 01:37 PM
Battery tender charging through cigarette outlet? imom BRZ First-Gen (2012+) — General Topics 13 01-11-2017 12:18 AM
Anybody using Battery Tender JR? bhbnuckle CANADA 14 11-26-2014 04:00 PM
Shorai Battery, Tender, and PTuning Tray jack43 Engine, Exhaust, Bolt-Ons 4 08-23-2014 12:42 PM
Suggestion: Marketplace / Tender forum ft_sjo Site Announcements / Questions / Issues 2 08-31-2013 04:03 PM
