Old 05-29-2019, 05:08 PM   #15
Fast13FRS
Fast13FRS's Avatar
Drives: 2013 Scion FRS
Originally Posted by aemravan View Post
From my experience with my local dealer, the only way I see them MAYBE agreeing to do the work on your car is if you pulled off anything aftermarket and towed the car to them (because unless you plan on buying all the factory parts obviously it wont drive).
Even then, what I envision happening (from numerous horror "after-the-recall-failure" threads) is IF your motor gets screwed up because they gunk it with gasket material they'll just say "it was modified previously so the damage is not ours to cover" and then you'll be out of a motor.
If it put up with the abuse thus far I would just drive it and see what happens. If a spring lets go, well then you pull it and fix it, or have it fixed. Maybe take some time to get some upgraded internals in there while you are at it.
I tried 4 local dealers a no go on that! I think I will just run it as I planned and let mother nature prevail!
Fast13FRS is offline   Reply With Quote
The Following User Says Thank You to Fast13FRS For This Useful Post:
ermax (05-30-2019)
Old 05-29-2019, 05:55 PM   #16
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by Fast13FRS View Post
Okay okay I did not start this for a shouting match over the strength of the engine. This one has had the PISS beat out of it for 13,000 miles most of which were track miles and greats me like puppy at the front door every night wanting to go for a run. I have been adding turbos to carb'd and F/I motors for over 20 yrs now and well know the risks involved.
And you are correct this is in no way comparable to a snowmobile engine they are way more intricate and complicated than this engine. pumping out more than 2 times the hp per CC this one did 394 hp on the dyno at the track 1098 CC's
I bought this one built by a professional tune shop and set up with plenty of miles to prove its pudding.
I spent 7 years in Montana, plenty of friends with the high dollar turbo/nitrous sleds. They would blow them up and laugh it off, drop another $10k and move on to the next weekend.
My wife's boss payed a shop to remove the snow from his sled every week. Payed. That's reliability right there.
maslin is offline   Reply With Quote
Old 05-29-2019, 06:08 PM   #17
Who is shouting?
Old 05-29-2019, 10:54 PM   #18
I know the motor was not cracked open and it was done in 2014 so long before the recall.
The stock motor will and does support 300 Hp and there are many out there to support the claim.
I think ol @JD001 was just fun-nen with you. He is from the UK, iffen ya get ma drift -
JD001 (05-30-2019)
Old 05-29-2019, 11:10 PM   #19
Fast13FRS
Fast13FRS's Avatar
Smile
Phew - I did not pick up on that I thought UK meant Un-Known?
The Following 2 Users Say Thank You to Fast13FRS For This Useful Post:
humfrz (05-29-2019), JD001 (05-30-2019)
Old 05-29-2019, 11:16 PM   #20
Okay okay I did not start this for a shouting match over the strength of the engine. .
YIKES, there, Fast13FRS, I don't read where anyone, including ol @Tcoat, is shouting at you -
No need to get your panties all bunched up -
See, when a new person comes on the forum, we have no way of knowing (unless they tell us) if they just got their drivers license and their parents tossed them the keys to a twin or they had cut their teeth on a 9/16 th in wrench and learned to drive with a 1930's some farm truck - ??
Several on this forum have found out that force feeding a FA20 engine shortens its life.
Your experience may differ -
Old 05-29-2019, 11:20 PM   #21
Well, sometimes, some of us think that ol @JD001 is from some "UnKnown" place -
JD001 (05-30-2019)
Old 05-30-2019, 05:28 AM   #22
JD001
JD001's Avatar
Drives: Subaru BRZ
LMAO!! Is there anything outside of America?
Old 05-30-2019, 06:19 AM   #23
I wonder just how many can tell the difference between United Kingdom, Great Briton and England without looking it up.
humfrz (05-30-2019), JD001 (05-30-2019)
Old 05-30-2019, 10:31 AM   #24
Fast13FRS
Fast13FRS's Avatar
Yes but the Aliens have not yet identified themselves -
Just yankin the chain - we are all brothers of the battle against the loss of the smell of racing fuel in the morning. "Some day this war will be over"
JD001 (05-30-2019)
Old 05-30-2019, 10:33 AM   #25
Fast13FRS
Fast13FRS's Avatar
Sorry guys toooooo much coffee this morning!
Old 05-30-2019, 11:24 AM   #26
JD001
JD001's Avatar
Drives: Subaru BRZ
Just take care, don't want you shorting the car seat heaters..
Old 05-30-2019, 11:56 AM   #27
RickyBobby
Drives: 2013 Firestorm FR-S AT
Why would it be mandatory in California? it is for valve springs braking wiping out the piston and then the motor not an emissions violation.
From here page 35: https://static.nhtsa.gov/odi/rcl/201...8V772-6522.pdf
"CALIFORNIA REGISTERED OWNERS The California Air Resources Board requires that emission related campaigns be completed prior to California’s vehicle registration renewal process; without this repair, you will not be able to register your vehicle during your next annual registration. Upon completion of this campaign, your California dealer will complete and provide you a “Proof of Correction Certificate.” If required, present the certificate to the California Department of Motor Vehicles (the “DMV”) when renewing your California registration as proof of campaign completion. If the DMV does not request the certificate, we recommend that you keep it for your records."
And from here: https://static.nhtsa.gov/odi/rcl/201...8V772-0191.pdf
"NOTE (Customers who live in the state of California)
The state of California requires the completion of Safety Recalls / Service Campaigns on emission related parts prior to vehicle registration renewal. In addition, the State requires that every vehicle must pass an
emission test (SMOG Check) every two years and before it is sold. Without the completion of this FREE Safety Recall, the California Air Resources Board (CARB) will not allow your vehicle to be registered. State of
California Regulations require Toyota to provide the Department of Motor Vehicles with a record of all vehicles that have not had the Safety Recall completed. Your Toyota dealer will provide you with a Vehicle Emissions Recall Proof of Correction Form after the campaign has been completed. Please ensure you retain this form, because the DMV may require that you supply proof that the campaign has been completed during your vehicle registration renewal process."
RickyBobby is offline   Reply With Quote
Old 05-30-2019, 12:21 PM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
Yes, indeed.. and better hurry up as it won't be United for much longer...
The Following User Says Thank You to JD001 For This Useful Post:
Tcoat (05-30-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring failure sandy s Issues | Warranty | Recalls / TSB 15 05-07-2019 09:00 PM
valve spring procedures ric342 Southern California 3 03-21-2019 08:46 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
