Drives: 14 BSP Edelbrock BRZ
OEM flywheel alignment pins
Will a stock flywheel allow you to install a pressure plate in the wrong orientation? I recently did an Exedy stg 1 kit and have way more harmonic resonances transmitted from the engine to the driveline now than I think I should. I read in various forums for other subarus about looking for the alignment marks to prevent being out of alignment by 120 degrees.
Heavy throttle under 2k results in basically everything in the car finding its resonant frequency. I know that driving like that is not ideal, but there was none of that prior to the clutch install. |
#2 |
Drives: '15 BRZ RA
I don't see anything related at the attached instructions. In general Exedy stage 1 & 2 kits are for performance oriented applications. If you are daily driving the car and you are worrying about NVH, then you should better go for the OEM solution.
| The Following User Says Thank You to nikitopo For This Useful Post: | Tcoat (05-28-2019) |
#3 |
I have an Edelbrock on the car, when I hit peak torque the revs would climb and the car wouldn't accelerate, hence the change to the stage 1.
I understand getting more NVH going to a heavier clutch, this just seems rather excessive for something that is still a sprung full-face disc and a pressure plate that is still light enough for me to not run the helper spring on the clutch pedal. If this is what results, so be it, just wanted to verify there isn't something going on that I could fix easily. |
#4 |
Señor Member
Is it fine above 2k rpm?
If the clutch was poorly balanced or out of alignment you would it to get much worse with revs. I am not sure why you would be using big throttle with load on the motor at such low rpm. My guess is it will be tune related or perhaps the extra load a supercharger adds causing the motor to lug. I have a light flywheel, trd engine and gearbox mounts and i can tell you our motor is not happy below 2k with much more than half throttle with those mods.
1974 TA22 Celica
2013 86 GT |
| The Following 2 Users Say Thank You to Turdinator For This Useful Post: | nikitopo (05-29-2019), Ultramaroon (05-29-2019) |
#5 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | nikitopo (05-29-2019) |
#6 | |
| Camber/alignment for Eibach Prokit and when should I get alignment? | Meanderchap | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2016 03:44 AM |
| DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
| which push pins? | sickmint79 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 09-10-2014 10:59 AM |
| instrument wiring, pins etc. | Basti | Electronics | Audio | NAV | Infotainment | 0 | 12-11-2013 03:49 PM |
| Bumper Pins | JackSmiley | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-12-2013 06:14 PM |
