Old 05-26-2019, 02:28 AM   #1
Qball1754
Drives: 2015 Scion FR-S
Weird noise coming from engine
Hello, first time posting here. kinda lost with this. i recently bought my 2015 scion-frs and a few days ago i noticed some abnormal noise coming from the engine while on startup and idle (had the car for about 2 months. took it to my mechanic and aside from the tensioner needing to be replaced. he said the noise which is almost like chirping or clicking is coming from the left head of the engine. he said it could be the timing chain, camshaft or the head itself. the weird thing is the car drives just fine with no issues and the only code i get when my CEL is on is for an EVAP leak. thought i'd post here and see if anyone had a similar experience. sorry for the long post! tried to upload the video of it but heres a link. https://www.reddit.com/r/MechanicAdv..._left_head_of/
Qball1754 is offline   Reply With Quote
Old 05-26-2019, 02:56 AM   #2
OwlDance
Drives: Halo 86, '19
Harmless noise. It seems like every FA20 does this. Boils down to either the direct injectors or valvetrain noise or the high pressure fuel pump (the latter of which doesn't make sense to me as this noise only comes on several minutes *after* start up but it's what Toyota told me after I took my new, 1600 mile car in for this very non-issue.)
There's lots of threads and stuff that make note of this noise as well. Perusing the link you posted quickly, I'm inclined to agree with the comment that says you need a new mechanic, or one that knows their way around the FA20.
OwlDance is offline   Reply With Quote
Old 05-26-2019, 03:21 AM   #3
Qball1754
thanks! i was getting a little paranoid lol. my mechanic used a stethoscope and said its coming from the left head only but i know his shop just recently started to do work on boxer engines (something about labor not being there why they didn't before). i did take it to another shop and they said everything was fine and the noise as normal. they didn't want to take apart the engine for no reason and they also said the tensioner but from other people it needs to be replaced
Old 05-26-2019, 04:25 PM   #4
Sounds like a FA20 engine running to me -
Old 05-26-2019, 04:34 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is because the DI/PI injection ratios change as the car warms up. You are getting more direct injection, and less port so the high pressure pump starts making more noise.
jcw99 (05-27-2019)
Old 05-26-2019, 04:40 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
It's totalled. I'll buy it for $5.
Old 05-26-2019, 04:49 PM   #7
tomm.brz
Drives: brz 2017 hksv2
Not true
Just at start and cold start, is using a lot of PI, between 100% and 50% but shortly after it switch directly into the regular DI/PI and despite 3 different tables for different coolant temperaturr are present, they are all the same, so the ratios don t change
tomm.brz is online now   Reply With Quote
Old 05-26-2019, 04:54 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by tomm.brz View Post
Not true
You just said it yourself right here. Maybe my word choice was poor.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
jcw99 (05-27-2019), tomm.brz (05-26-2019)
Old 05-26-2019, 10:01 PM   #9
Qball1754
thanks for the responses guys! my mechanic used a stethoscope on the left head and around the engine and only heard the noise coming from the left head and nothing else so i started to get paranoid and was also told the tensioner is moving too much but i've heard different things on that
Old 05-26-2019, 11:41 PM   #10
OwlDance
For what it's worth I noticed my tensioner moves around a lot as well when idling normally. I'm also inclined to believe that's normal as well.
Old 05-26-2019, 11:56 PM   #11
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
High pressure fuel pump is on the left so that explains that.
Old 05-28-2019, 02:17 AM   #12
Qball1754
thanks! it only happens when i first turn the car on (whether its hot or cold), idling or just. i was worried its an engine problem but I'm glad its just the high pressure fuel pump
Weird noise coming from rear wheels. aerylus Issues | Warranty | Recalls / TSB 6 02-07-2017 11:34 PM
Eibach Sportline Weird Clicking Noise coming from car VeganGirl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-25-2016 04:19 PM
Weird Crinkling noise coming from center console fitcious Scion FR-S / Toyota 86 GT86 General Forum 14 03-20-2016 05:56 PM
Weird rattling noise in cabin coming from front left Webster10 Scion FR-S / Toyota 86 GT86 General Forum 36 03-01-2016 05:44 PM
weird noise sound coming around header area shern Issues | Warranty | Recalls / TSB 28 02-19-2016 08:39 PM
