Drives: 2013 Raven
Dented header
I'm upgrading my cooling system and went to pull the hose off the bottom of the radiator and noticed a dented header. Luckily my bottom panel saved my car from any more damage.
I contribute this to the construction on 281 north of 1604. I knew I hit a rock and had no choice. It was that or hit a car. I'm sure this has caused interruption to the air flow. Question is how much? Should I replace the entire header or just have someone cut and weld a new piece? It's a Tomei EL. ![]() ![]() Sent from my SM-N960U using Tapatalk |
#2 |
Drives: Q5 + BRZ + M796
That is legit. Lucky it didn’t hit/crack the oil pan.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | KDad2 (05-25-2019) |
#3 |
Drives: 2013 Raven
And I'm glad it didn't hit my fumato valve.
#4 |
Drives: 2013 frs red
Might be able to heat it and pull dent out. Also, I dont believe it will hurt performance much.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | KDad2 (05-25-2019) |
#5 |
I was trying to find the video, but it was taken down from youtube. It was the Engine Masters episode where they bash headers and dyno the car. In short, bashing the headers didn't do much to alter power.
Could it cause a hot spot? Could it lead to a restriction that leads to hot gases working back into the cylinder increasing the chance of knock? I don't know, but their data was fairly convincing. There will definitely be a loss of flow, but it probably depends on how much it is smashed. To use an example: -A square with a size of 3x3'' has a circumference of 12'' and an area of 9 square inches. -A squished square (aka rectangle) with a size of 4x2'' has a circumference of 12'' and an area of 8 square inches. -What about in half? 4.5x1.5'' = 12'' circumference and 6.75 square inches. It still isn't a huge loss of area. -A more squished with a size of 5x1'' has a circumference of 12'' and an area of 5 square inches. Now we are seeing a bigger jump in area. As you can see, the second inch lost took a bigger hit to the surface area than the first inch. This is what Engine Masters found, that small to medium sized dents did little to flow, but large dents that reduced the diameter by greater than half is necessary to see some drop. Even then the drop wasn't significant, mostly happening on the top end; I think they even gained a little on the low end.
| The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#6 | |
Drives: 2013 Raven
The size is 2" x 1-1/2" x 1/2". Sent from my SM-N960U using Tapatalk |
| The Following User Says Thank You to KDad2 For This Useful Post: | Irace86.2.0 (05-25-2019) |
#7 |
If you're concerned enough, take it to weld shop and see if they can heat it and reshape it. I've done them in the past. Drill some pull holes and weld them up once your finished.
#8 |
Drives: 2013 Raven
#9 | |
Good luck with your new business - humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#10 |
Drives: 2014 GT86
I also saw that episode and unfortunately when i wanted to find it again to reference at similar topic, couldn't find anymore.
Funny bit was that in first "hammering mod" iterations they even saw power increase on that dynoed engine . I'm sure that this mod would have been favourite for TG's Clarkson, after all, hammer is only tool he can use, and he is always after more "POWEEER!!"
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Irace86.2.0 (05-25-2019), KDad2 (05-25-2019) |
#11 |
Wrap it back up, beat the ding out of the bottom cover, and fuggetaboutit.
#12 |
Drives: 2013 Raven
Got it done. Did a quick patch job with the wrap. But decided not to hammer out the bottom panel. Instead I went with Beatrush that's been in a dust covered box.
| Dented rocker panel | daftpunk | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 49 | 08-15-2017 11:41 PM |
| Dented fuel injector? | pgranberg11 | Engine, Exhaust, Transmission | 7 | 07-14-2015 01:58 AM |
| Somebody dented my FR-S | smallfun | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 08-22-2014 03:54 AM |
| Door dented and scratched | FR Sports | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 04-07-2013 06:44 PM |
| dented bumper | drei | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 12-03-2012 02:14 AM |
