Drives: 1996 Toyota celica
Only one seat warmer light is turning on?
Is this normal? It appears to still be warming up on my seat (to be honest I can’t really tell if it’s just my body warmth or the seat
https://imgur.com/a/uqyk8c8 |
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Both seat heaters are fused independently. SEAT HTR LH and SEAT HTR RH.
It's OK to replace the fuse, but if it blows again you'll have to replace the heater as it's likely shorted, you wouldn't want to keep replacing fuses and using the heater or worse, use a higher amp fuse and burning a hole in the seat. |
#3 | |
#4 |
The way the circuit is designed, you could have a light on the switch but no heat if the power circuit and switch ground were OK but the heater element circuit was open, or no light and no heat, which would be a bad power circuit (this includes the fuse).
I don't know how used car warranties go in AUS, but if it's been a week, you probably have a recourse. don't mess with it and bring it to them. Replacing a seat heater yourself isn't necessarily hard, but it's a pain in the butt. |
#5 |
Drives: Subaru BRZ
You have a requirement for heated seats in Australia??
#6 |
Australia is pretty big, so between the north and south there should be a good difference in temperatures. And while it's bisected by the tropic of capricorn, a quick glance through a google search tells me some regions can go down to the single digits celcius during winter, so while it's not dangerously cold (like where I'm from), seat heaters, in short bursts, are comfy in that range. Here people keep their seats on full burn from november to april.
My 86 doesn't have any
#7 | |
Drives: Subaru BRZ
#8 |
| The Following User Says Thank You to humfrz For This Useful Post: | JD001 (05-12-2019) |
#9 |
The butt heater switches are notorious for burning out. They short closed when they get hot and let go.
#10 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Could just be the little light inside the switch; this is what happened to mine.
The light inside the driver's-side switch no longer turns on, but the seat heater itself still works perfectly. I was told by my dealer that you cannot replace the light by itself; you have to replace the whole switch, and a switch was $50 plus tax, so I elected (for now) to just live without the light since the heat itself is still working.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | Ultramaroon (05-13-2019) |
#11 |
Drives: 2013 Subaru BRZ
I have this same issue. Heater still works, but the light is out.
Sent from my Pixel 3 XL using Tapatalk |
| The Following User Says Thank You to ftpwny For This Useful Post: | SLVRSRFR (05-14-2019) |
#12 |
Drives: 2013 DGM BRZ Limited
I've had the same issue for years. Seat still works fine.
#13 | |
| Speed wobbles and abs on light turning | frstplace | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2018 07:28 AM |
| Turning off air bag light | s0sl0w | Electronics | Audio | NAV | Infotainment | 2 | 07-16-2016 11:24 PM |
| Turning off maintenance required light | Prowl647 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-18-2014 02:01 AM |
| Dome light not turning on | Vincenttam | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-12-2014 03:51 AM |
| Center console seat warmer trim, Limited only | BRZPDX | BRZ First-Gen (2012+) — General Topics | 16 | 04-18-2013 03:55 PM |
