Old 05-10-2019, 07:15 PM   #15
Audio
Drives: 16 FR-S Raven
Originally Posted by DandoX View Post
  • The option to display what gear Im in for a manual transmission
  • Shift light is awesome
  • how easy and casual it is to spin some tires leaving a stop light
  • Also how casual it is to break the tail out in a turn
  • the driving position its easy to take for granted after a while
  • how easy it is to change the oil
  • pillar less doors
  • trunk space for this size sports car
How easy it is to change the spark Plugs.
Audio is offline   Reply With Quote
The Following 2 Users Say Thank You to Audio For This Useful Post:
Dadhawk (06-07-2019), MJones_RB (05-10-2019)
Old 05-10-2019, 07:22 PM   #16
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I just wish it would be on even when you're not on the gas pedal.
In mine which is a 6 speed its on all the time unless you put in the clutch, even if I totally let off the gas. Is yours auto or maybe they changed something with how it works?
DandoX is offline   Reply With Quote
Old 05-10-2019, 07:23 PM   #17
DandoX
Senior gif poster
DandoX's Avatar
I still haven't gotten used to that lol. At least its every 60k.
Old 05-10-2019, 07:42 PM   #18
p1l0t
p1l0t's Avatar
It's free with the valve spring recall all you have to do is buy the plugs no labor. Worked for my Fiancee's 2013 Impreza got her a nice new oil filter and accesory belt tok ahahaha. I don't think my 2016 is getting that recall though.
Old 05-10-2019, 07:43 PM   #19
p1l0t
p1l0t's Avatar
Mine is 6 speed but maybe it's all computer now (rpm vs speed to get the ratio) instead an actual sensor?
Old 05-10-2019, 07:53 PM   #20
DandoX
Senior gif poster
DandoX's Avatar
It's free with the valve spring recall all you have to do is buy the plugs no labor. Worked for my Fiancee's 2013 Impreza got her a nice new oil filter and accessory belt tok ahahaha. I don't think my 2016 is getting that recall though.
My plugs where taken care of at the 60k service, and I did my J02 recall at 80k. Dealer offered to do plugs if I wanted to just pay for the part but I declined since its been 20k since I last got new plugs. So at 120k is the next plug change for me. If Ca didn't force me to do the recall right away I would have sat on it until 120k.
This weekend is a brake fluid flush and possibly new pads and rotors depending on how worn things are.
The Following User Says Thank You to DandoX For This Useful Post:
p1l0t (05-10-2019)
Old 05-10-2019, 07:56 PM   #21
DandoX
Senior gif poster
DandoX's Avatar
Strange they would change how that works. I'll double check but I'm almost positive that my gear indicator shows the gear until the car is in neutral from the clutch or stick. I can't get why you wouldn't see the gear when the throttle is not pressed, not like your no longer in gear just because your not giving throttle.
So if your going down a steep hill and your in a lower gear for engine braking and just using the brake pedal, it won't show what gear your in in the display?
Old 05-10-2019, 08:02 PM   #22
p1l0t
p1l0t's Avatar
California FORCED you? Communist bastards.
Old 05-10-2019, 08:14 PM   #23
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
1. Those weird gymnastic moves you have to do getting in and out of the car. Automatic, easy, and fast for me after living with the car for years, and a lot of fun to watch passengers do for the first couple times.
2. Rattles, like everyone else has said.
3. Seating position.. just about perfect, and forget how perfect it is until I drive something else.
HOWEVER... all of those things are fading rapidly because I haven't had my @#$@#4 car for @#$@#$@#???!!! two months and counting.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
Old 05-10-2019, 08:23 PM   #24
86MLR
86MLR's Avatar
Whilst the FA20 plugs are trickier to change than a IL4 they really aren't that hard if you have basic spanner spinning skills and some jack stands.
It takes me longer to wash my car than change/inspect the plugs.
I love the look of my car, it looks like a 80's-90's Jap car from some angles, and a modern car from other angles.
It's not trying to hard to be sporty, it doesn't need to, it is a light, 4 cyl, RWD manual coupe, true sports car DNA.
As for the power, it has a extremely good power to weight ratio, considering it's a cheap mass produced car. If you want more power 200hp atw is only some parts and a good tune away.
Its just like a S chassis, only not old.
If you want more power then open up your wallet, just like you do for every other make and model of car that people buy.
People don't realize how lucky they are to have the twins, always complaining that they want more, usually for less money.
Think about this for a second, what other new lightweight 4 cyl manual coupe would you buy for the cost of a twin if they axed the twins tomorrow?
All I can think of is the MX5 RF, which is what I would buy if there were no twins available.
Opinions may vary
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
humfrz (05-10-2019), MuseChaser (05-10-2019)
Old 05-10-2019, 08:26 PM   #25
DandoX
Senior gif poster
DandoX's Avatar
They forced me, refuse to renew my registration if the recall is not performed. In Ca it is mandatory because it involves parts related to the emission system. More like bureaucratic bastards. Ca has some seriously shitty vehicle laws.
Old 05-10-2019, 08:34 PM   #26
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
hmm think you're mistaken..I have a 2016 as well and like DandoX pointed out, it always shows the gear you're in unless you have the clutch pressed in..
HKz is offline   Reply With Quote
Old 05-10-2019, 08:42 PM   #27
DandoX
Senior gif poster
DandoX's Avatar
The normal mx5 club and RF are really the only other alternatives in that price bracket but the 86 is still notably cheaper.
MX5 RF is more expensive, starting above 34k. Where a new 86 is below 28k. Both are with zero options. Also hard not to mention on top of the additional money sacrifice to own a mx5 you get the luxury of having a car that has next to zero practicality for anything except transporting a driver 1 passenger and maybe 2 small backpacks if you really cram.
If you ever have put 4 full size wheels in the back of a twin you can totally appreciate the cargo space which is really good for a small cheap sports car.
Old 05-10-2019, 09:13 PM   #28
p1l0t
p1l0t's Avatar
Yeah exactly.
The little things... Be-Are-Zee BRZ First-Gen (2012+) — General Topics 130 04-26-2016 08:00 PM
Things on your car that you have grown to like... JD001 BRZ First-Gen (2012+) — General Topics 109 04-03-2016 05:28 PM
Has anybody grown attached to their stock wheels? FR_Soldier_77 Scion FR-S / Toyota 86 GT86 General Forum 43 02-06-2013 04:07 PM
